Convertible top adjustment?
  • Night Wolf
    • 85
    I have searched, and found out how to adjust the windows... but it's more then just that.
    The top itself appears to be misadjusted. from the PO, it was replaced about 2yrs ago. It looks like the actual top should be maybe 1/8" forward, as the rear windows do not seal up into the top, and the top does not seal against the windsheild frame correctly.
    I was thinking about finding someone local that does convertible tops and have them check it out, but I'd hate to spend money on someone else if it is something I'd be able to do myself. Anyone adjusted one befor?
    ~Rick | 1990 325iC ~Noelle - Her build/cleanup thread http://r3vlimited.com/board/showthread.php?t=179507
  • M5wanaB
    • Aug 2007
    • 405
    the top is adjusted with shims on the 4 mounting bolts on each side in the top storing compartment. Chances are the last person to replace the top did not put the shimms back in the way they were supposed to. I would try and just loosen the bolts and move the whole frame till you get it lined up and re-tighten all the bolts. You may get lucky but if not maybe some washers could be used for shims or check out a local salvage yard for some. good luck.
    1991 325iC w/ 75k Original Miles, Brillantrot, 5-speed, 16" BBS RX's, Black Leather Sport Heated Seats, LSD, and Diving Boards for life!!!:D
    • ethirdy
      • Nov 2007
      • 406
      I keep mine down :)
      Seriously, I read the section in the bently regarding this, and its scurrrry.
      There's the fore/aft adjustment with the bolts, then there's two mounting points on each side where shims can be added/removed to adjust/tweak the height. That leads to a LOT of adjustment to get it just right.
      Mine closes. It leaks like a sieve if I'm ever caught in the rain. Then again, I don't have any front windows installed, so I've accepted that I'm going to get wet no matter what :)
      Originally posted by alpinaclone
      Since the real economy is in the shitter, I say we start our own.
      This is how it works; you buy my junk, then I will buy more junk and so on so forth etc. etc. Think of the future of your children and buy my stuff.
      • 87cabrio89is
        • 38
        Check to ensure that you have the caps for your centering pins, this might be the issue.
        • ill4noreason
          • 2710
          Just installed a new top and the horizontal line are about 1/2 to 3/4 inch off from the horizontal bars. I think it may be manufacturer error or just how they make them it was a gaah 580.00 top.
          My Multi car part out. Need a part? Pm me...
          http://www.r3vlimited.com/board/showthread.php?t=193051
          Need 24v swap parts? How about a LSD? Plastic Bumpers? Or anything else click here...
          http://www.r3vlimited.com/board/showthread.php?t=215044
          Have you done business with me? If so leave me feedback here...
          http://www.r3vlimited.com/board/showthread.php?t=188307
          • N2MYE30
            • Oct 2007
            • 5536
            I cannot find it right now but somewhere on the interwebs, BMW made a video on how to adjust these tops. The hunt is on!
            COTM
            • Hey-U
              • Mar 2008
              • 560
              This will help:
              • bmwguy325is
                • May 2011
                • 1263
                I ussed to throw small children on top. BAM all seals lined up. That simple
                sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
                • 95BMWIC
                  • Apr 2012
                  • 353
                  Even though it is 6 years old..
                  this thread saved my sanity..
                  I replaced my daughters soft top a year ago (frame and all) from a junk yard and installed it with the existing shims..
                  Door is not closing without window hitting and the top windshield seal wont hold out the water..
                  The videos really help..
                  • Mike36
                    • 1079
                    Bump because this was exactly what I was looking for!
