Answers to Common Sunroof Problems
    sunroof adjustments:
    http://e30.bmwdiy.info/sunroof-adjust/index.html
      I need to remove #9 in the first diagram to do my headliner, how do i do that?
        Heres one for you
        The sunroof motor has 3 stops right?
        mine will stop but if i hit the button again it keeps going and it doesnt seem to be able to keep the timing right anymore. do i need a new motor?
          Originally posted by NC325iC View Post
          Heres one for you
          To be honest with you I have no idea man, I'm not really a sunroof guru I have just taken my own crank sunroof apart a million times. I suggest posting the question in a new thread, I'm sure others have had the same issue.
            Whenever I close my door, the sunroof pops up a little bit. Is there anything I can do to fix that?
              Adjustment. Read post #1
                my crank sunroof works alright but the roller black piece is missing, how do i remove one from another car? i have a parts car and i cant get it off to swap it. i could even replace the whole crank peice if i knew how to remove it. also the lever doesnt click back up and hold after to open or close the sunroof, not a big deal to have it hanging, but id like it to tuck up like its supposed to. is this an easy fix? thanks - phil.
                  ok heres a question of mine.. my little brother was standing on the car a while ago.my pops let him. then he just droped and landed on a corner of the sunroof.. since then the switch works. but its like the motor is not grabing and it will not go up or down
