Timing Belt / Water Pump DIY - Step by Step Pictures
  • Das Delfin
    • Sep 2014
    • 2293
    #226
    Good luck with the A/C. That will probably be my next project as well
    • sdhakko
      • Jul 2015
      • 7
      #227
      So working through this today, and the allen head screws on the rotor immediately stripped. And I just made it worse... tried to get them out another way and got one screw out.... because it broke part of the rotor off along with what the rotor attaches too.... SIGH
      How hard it is to replace whatever it is that the rotor mounts on to? Thanks!
      • smokeyyank
        • Jun 2015
        • 31
        #228
        There should be a torx head bolt that is holding the cam gear in place, you should be able to remove that in order to replace your rotor and other broke part. I just replaced my cam shaft seal yesterday and it does all come out. Also if you don't have the exact socket, I used a 12 point socket, I think it was 7/32 but I may be wrong. Just make sure you don't move the cam unless the timing belt is still attached or if it's already off use a screw drive to work against the bolt.
        • sdhakko
          • Jul 2015
          • 7
          #229
          Here you can see the broken piece. So I should wait and take it off until after I get the TB off? Also what will I need to replace exactly, since I would like to see if I can hunt this down locally.
          • Das Delfin
            • Sep 2014
            • 2293
            #230
            My rotor bolts stripped too. Just hammer in a torx socket and take it out with that
            • sdhakko
              • Jul 2015
              • 7
              #231
              Trying this now, now the torx bolt is stripped also. Used a e12 now trying to hammer/force an e10 on there. Not sure what to do to get the bolt out of this doesn't work.
              Any ideas?
              • smokeyyank
                • Jun 2015
                • 31
                #232
                Only other option would be getting a bolt removal tool. Make sure you get a nice big fulcrum for leverage to get the bolt out with out too much jarring. If that doesn't work I'm kind of at a loss unless you replace the cam......
                • dnguyen1963
                  • Nov 2011
                  • 2648
                  #233
                  Here is a video for those interested.
                  • sdhakko
                    • Jul 2015
                    • 7
                    #234
                    Thanks everyone for the help! Couldn't have completed this job without this walk through and the quick responses from everyone here. On the Cam bolt, I ended up saw-zalling the cam adapter off so that I could get a better grip on the stripped bolt, which I used a pipe wrench to get it out. Fun times!
                    But learned a lot through doing this, I am excited for the next project, which is probably AC and then shocks/springs.
                    • staysideways
                      • Dec 2013
                      • 373
                      #235
                      My car wont start after timing belt
                      1989 E30 325i Sedan Alpine
                      • estoguy
                        • May 2013
                        • 1087
                        #236
                        Okaaaaay... need a bit more info. When you turn the key, Is it turning over at all?
                        Estoguy
                        • e30onBBSs
                          • Dec 2014
                          • 1347
                          #237
                          To get rotor bolts out use lots of penetrating oil, and get yourself one of these with some allen sockets. Great little tool! Put your socket on it and whack it with a hammer, and it turns to the left with all the force of the hammer. Deadblow preferred
                          http://www.zoro.com/westward-impact-...m_campaign=PLA
                          BMW tech
                          Umass Amherst
                          05 wrx sti
                          • staysideways
                            • Dec 2013
                            • 373
                            #238
                            Yea it cranks fine not valve knock or anything double checked timing twice and its correct,i have bright blue spark and fuel beacause plugs are getting wet
                            • davvik
                              • Dec 2013
                              • 49
                              #239
                              Did you put your crank sensor back? Make sure your cap and rotor are correct?
                              Sent from my XT1032 using Tapatalk
                              • staysideways
                                • Dec 2013
                                • 373
                                #240
                                Yea i put the crank sensor back and the rotor stays just behing #1 when cyl1 is at tdc
