Good luck with the A/C. That will probably be my next project as well
Timing Belt / Water Pump DIY - Step by Step Pictures
So working through this today, and the allen head screws on the rotor immediately stripped. And I just made it worse... tried to get them out another way and got one screw out.... because it broke part of the rotor off along with what the rotor attaches too.... SIGH
How hard it is to replace whatever it is that the rotor mounts on to? Thanks!Comment
There should be a torx head bolt that is holding the cam gear in place, you should be able to remove that in order to replace your rotor and other broke part. I just replaced my cam shaft seal yesterday and it does all come out. Also if you don't have the exact socket, I used a 12 point socket, I think it was 7/32 but I may be wrong. Just make sure you don't move the cam unless the timing belt is still attached or if it's already off use a screw drive to work against the bolt.Comment
My rotor bolts stripped too. Just hammer in a torx socket and take it out with that
it's a Kenny Powers quote on wheelsComment
Only other option would be getting a bolt removal tool. Make sure you get a nice big fulcrum for leverage to get the bolt out with out too much jarring. If that doesn't work I'm kind of at a loss unless you replace the cam......Comment
Thanks everyone for the help! Couldn't have completed this job without this walk through and the quick responses from everyone here. On the Cam bolt, I ended up saw-zalling the cam adapter off so that I could get a better grip on the stripped bolt, which I used a pipe wrench to get it out. Fun times!
But learned a lot through doing this, I am excited for the next project, which is probably AC and then shocks/springs.Comment
Okaaaaay... need a bit more info. When you turn the key, Is it turning over at all?Estoguy
Need a photographer, come visit my site: http://estoguy.wix.com/unique-perspectivesComment
To get rotor bolts out use lots of penetrating oil, and get yourself one of these with some allen sockets. Great little tool! Put your socket on it and whack it with a hammer, and it turns to the left with all the force of the hammer. Deadblow preferred
http://www.zoro.com/westward-impact-...m_campaign=PLABMW tech
Umass Amherst
05 wrx stiComment
Yea i put the crank sensor back and the rotor stays just behing #1 when cyl1 is at tdc
1989 E30 325i Sedan AlpineComment
