Front wheel bearing replacement.
    Just rent it. It's free.
    2008 335i - n54b30
    1991 318i - m52b28
    1994 fzj80 - LAND CRUSHER
      So yea, just did mine today. I rented the slide hammer and bearing puller from autozone so I was set. I tool the hub/axle nut off with the sears socket, and the hub/bearing assembly fell right off and The inner race just popped right out of the hub. I didn't even need the puller. Either I was lucky or my bearing was truly fucked lol.
        Can someone do a write up for replacing the rear wheel bearing? That would be greatttt.... >.>
        out dated sig is out dated
          There should be a few of them already. Go thru the whole diy section.
          Here you go
          http://www.r3vlimited.com/board/showthread.php?t=127740
            I have done my share of rear wheel bearings, you need http://www.harborfreight.com/fwd-fro...ers-66829.html
            Ill rent it to you
              Did you buy a 36mm socket? Care to let me borrow it to do mine?
              1991 e30 328i M52 swapped: Gone
              1995 e34 540i/6 1 of 76 Clean
              1985 e28 euro 525i the daily
                Yea man just hit me up. I'll snag it from my dads house and you can come by the shop to pick it up.
                  Yo Ian. I just might take you up on that offer. But not anytime soon. My rear left is in dire need of a new wheel bearing..
                    is this the Sears socket you guys are using?
                    I picked up a 36mm deep-well, 6 point, impact socket from amazon - and it looks like it's gonna be too thick..
                    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                      Thats the one I picked up.
                        Thanks
                          fwiw - the 6-point impact from Amazon fit with room to spare
                          (i have a weird stigma against 12 point sockets)
                            I also wanted to throw another nugget out there after talking with GC Mark (Mark from Ground Control), if they are assembling you new coilovers, have new hubs shipped to GC directly instead of yourself, and GC will install the new hubs free of charge.
                            This is the route I'll be taking in a few months.
                            www.gutenparts.com
                              www.amazon.com/gp/product/B001Z0U58Q
                              12point is crap because it can easily round the bolt/nuts. 6point ftw!!
                                I used the 12pt and was done with both sides in less than 30mins. Great write up!!
                                Originally posted by csermonet47
                                Vlad, you are handling this quite unprofessionally.
                                Also, you are a cock with tacky taste.
                                That is all.
