View Post
Front wheel bearing replacement.
Thats how the Bentley makes it sound.
Also I broke down and bought a 3 arm....
ส็็็็็็็็็็็็็็็็็็็็็็็็็Originally posted by blunttechI need you to exfoliate my ballsack
Bump!!!
Just did this today!!!
Im rolling smooth once again. Thanks for the write up!
I wish the rear was this eazy
Transaction Feedback
Originally posted by KenC View PostMake sure to get a puller with a very thin threaded rod. If it's too large it will try to thread into your spindle.
Originally posted by ///digitalme View Postso how do you install a new one???
mine fell apart when i tried to install it
whats the procedure to install it? need any
special tools?*sigpic
Originally posted by randomtask37 View Postanyone know if this 36mm socket will work? I cant tell if its thin wall enough.
I've used Tekton before and been happy. Its cheap. About half the price of the other amazon socket someone else recommended.
I always use a Craftsman thin walled socket. Fits right in there. If you don't want to keep it just return it when you're done, but its worth having a 32mm socket. Its a very common size for bigger nuts.
EDIT: Its cheaper too.
I bought mine from PepBoys for under $11. It looked just like the Tekton in the pic, impact gun 36mm, deep socket. Fit perfectly, but not much room to spare. Best of luck.
