will an e36 318is radiator fit into my e30 318is? the mounts look the same but will it fit perfectly?
also im replaceing waterpump(corroded) and radiator(discolored), to see if the problem will stop before jumping on a headgasket problem, now if the headgasket is blown what are the chances that the head is warped considering the aluminum block?????
