Replaced my alternator and took a few pics thought it might help someone.
This was done on a '89 325i
Very easy job should take about: 30min - 1hr
Remove the airbox
Take the tension of the belt so you can remove it of the alternator
Close up
remove the second lower bolt from the alternator
use as needed
remove old pulley and fan
put everything back on the new alternator and reverse the steps
Remove the airbox
Close up
use as needed
