It's a cool upgrade if your old POS "pushy" e30 switches barely work or not at all, and stick. Looks way better too.
DIY - E36 window switch retrofit
Originally posted by Justin B View PostIt's a cool upgrade if your old POS "pushy" e30 switches barely work or not at all, and stick. Looks way better too.
Can you rehost the pictures for this? :pErick Mahle | FullOpp Drift | YouTube
..::Support FullOpp::..
FullOpp Stickers for sale!
Feedback Thread
Originally posted by Mr. Anderson...one of the most hardcore E30's around. :D
So I am about to start this mod on my 89 iX. I have large white base switches and if i under stand correctly the pins are numbered like this,:
123
456
or in my case 1=bl, 3=br, 4=gr, 5=red as shown below
and as you can see on the lower pic as the pins look like from above correspond as:
45
13
Now, should the key that was made a few pages back that Franco made work the same for mine even tho it was a blue base? Or better yet does anyone have a pic of the white base switches wired in? Thanks in advance.
AWsigpic
Yea I've seen that before. But I just tested them and here's what worked for me.: The e30 wire colors are...
1 - Purple
3 - Both Browns
4 - Black
5 - Green
(the numbers are the pins& wire colors are e30) which someone posted way back
My only issues now are to figure out which wires for the rear windows do what as they are different colors. Franco, is the above what you did? Also, do you know the wires for the rears? How exactly did you plug your e30 wires into the switch base? Thanks again.
AWsigpic
my wire right up all the wires were the same color I think
but this is the way i wire them to the base I used the following item below
Originally posted by franco90 View Posthere are the part number that you need
to make custom wires for blue switches
I hope this helps some one
I've always been proud of being a Marine.
I won't hesitate to defend the Corps
"Supersquad"
"Prostitutes are a sub-category of Amusement Parks"-
