Just posted a WTB thread at Bimmerforums. I used one of your pictures for reference to what i need if thats okay josh :)
DIY - E36 window switch retrofit
Re: The E36 window switch retrofit thread
Originally posted by Eurospeed88They will run about $2.25 each from the dealer, however KenCopperwheat said that he got them from BMA for about $1.80 each.
Now to find some switches...Originally posted by Grueliusand i do not know what bugg brakes are.
Josh, it looks like there's a slight gap between your trim pieces and center console. I had the same 'problem' with one of my switches. You have to enlarge the hole a tiny bit more to get it to sit perfectly flush, but then it may not be as snug as before. I had the pleasure of using an extra console when I did my swap so it was out of the car. I opened up the holes large enough, then used hot glue on the backside of the console to hold the trim pieces in place.
this should clear up all of the questions i get pelted with when I say to use the large base switches and four door/sunroof trim pieces :roll:
haha good job Josh
Thanks, Bryson. I noticed the gap as well, I think when I pull the shift boot to vacuum all the dust and stu ff out this week (I had to take off somewhere right when we got it done), I may open up the holes a tad larger, and glue them, like you said. But all in all, I'm very happy with them.
I think the one touch switches are switching a low current draw relay, rather then switching the power window current.
The wire size is drasticly different.Tenured Automotive Service Professional - Avid BMW Enthusiast
https://mtechniqueabs.com/
Inline of 2 fatty green wires.Tenured Automotive Service Professional - Avid BMW Enthusiast
these are the switches i have, yet another different type from the ones listed...these are the 4 switches out of an e36 4-door...
i noticed that all 4 switches i have only have 4wires, but they are the LARGE white base and not the small white base...will these ones work??IG: @Baye30
Large white and blue base work. Wire colors will vary.Tenured Automotive Service Professional - Avid BMW Enthusiast
Originally posted by MR 325gold, I have the same ones you have there in my car. Large white base. Both of mine have different color wires, lolIG: @Baye30
