Hi guys, I have an issue with my drivers side window regulator..the plastic tab that holds the glass has broken so my window falls into the door. I have purchased a used regulator from our friend on the board here without the motor.
Question: Does anyone have a DIY stepwise approach to replace the regulator? What all is involved and is there anything special as far as bolts or torx? I will use my OLD motor since it works fine..I just want to replace the regulator mechanism.
Thanks for any help or links that you guys can provide before I tackle this project. PM any links if you guys can!
-Rob
-Rob
