A common issue BMW e30 owners have is the look of the front diving board (aluminum) bumpers with the license plate holder. In many states you are not required to have a front license plate so you either have an empty plate holder or you buy one to support your favorite team. Thats what I did.
First you must find a REAR bumper impact strip from another bmw e30.
Once you have the strip you need these washers, nuts and bolts.
Next remove that bumper. It only has 4 13mm bolts holding it on to the car.
Next remove everything from the front bumper. There are 4 13mm bolts holding the bumper shocks, and a bunch of 10mm bolts holding on the bumper trim.
Once you have removed the trim and shocks the aluminum bumper will be bare.
Now before you can install the new trim you will need to bend the license plate tabs back. I just hit them with a hammer.
Now take the washers and bolts and insert them into the trim.
Next line up the bolts with the existing holes on the bumper and secure them to the bumper.
Finally the bumper should look like this.
Now reinstall the front bumper to the car.
Voila, no more license plate holder.
One VERY IMPORTANT thing to remember is that you will need to relocate the turn signals that were on the bumper before to another location and there are several options.
#1 You can find some BMW headlights with the integrated blinkers.
#2 You can relocate the blinkers to the area behind the grill.
#3 Be creative?
#3 Be creative?
