I will be adding part numbers and more info in the next week
OK So I know I was looking for this and could not find it.
It took me a little bit of time to figure this out and get it done.
If you have an Auto Top Vert and want to convert it the Manual top.
Here is what you need:
This is the Driver side Hinge and Lock Assembly and Cable:
This is the Manual release. When you pull the handle and the locks open you have to reach in and un-lock it manually so it doesnt pop open on it's own.
This is the Passenger Side Lock Assembly and Cable:
This is the Handle to open the top: (You dont need to buy the whole speaker cover. I trimmed mine to the opening needed and installed the handle.
Additional pictures. This is also got the Part that goes in to the handle that holds the cables and the end caps:
You will need a 11mm for all the screws..and the only other thing needed is a Phillips head screwdriver. Not very difficult to install or switch over.
http://realoem.com/bmw/showparts.do?...05&hg=41&fg=55
and
Also:
and
Also:
