DIY: How to install an OEM skidplate.
  • mpowerful
    • Jul 2013
    • 1273
    In case any of your are considering installing an OEM skidplate this is how I did it. I have seen two other methods (actually with very little info or pics). One suggests welding bolts to subframe and core support while the other mentions using "crush nuts" which I am guessing are some kind of insert/captive nut thing. Anyway I did neither.
    I picked up this OEM skidplate at the Consignment Shed in Norcross (atl) GA (hit them up for lots of good e30 parts http://www.theconsignmentshed.com/ ) last week while up there seeing girlfriend. I live in new orleans and the front of my car is lowered approx 2 inches. The streets here in Uptown are probably the worst in the country. I will take the pepsi challenge if you dont believe me. We replace a lot of busted oil pans at the shop over the year (especially vw/audi which are even stupider than e30). Anyway I picked this plate up for a good price but had no clue how to install. So I just went at it and figured something out.
    Time: 2 hours
    Tools: I used the following although some other things can be used.
    3/8" impact
    Drill
    Radiator Hose tool/seal puller
    Lift
    Screw Jack
    Magnet
    Here are the bolts I used. I grabbed em out of the bin so I dont know size but they are metric.
    First thing I did was go to subframe side. I found the two holes that corresponded to the mounting holes in the skidplate. The idea here is to push the bolt through the bigger open hole in front and then get the bottom of the bolt such that you can pull it through using a magnet. For this task I used a dental pick to maneuver the bolt into place and when you see bottom of a bolt use a strong magnet and it will pull right through. In this photo you can see the head of the bolt through the big hole. Just push it so the other end is over the small hole. Also I put a lock washer under head of the bolt.
    Bolt over the hole. Now use magnet to grab it and it will right itself and fall through.
    Do the same for other side of subframe. Next this is important. To make it easy to get the plate on and off double nut the bolt into place. Put a nut on the bolt before you put the skid plate on. I used a seal puller/rad hose tool to put pressure on the top of the bolt from the big hole, then I banged the nut tight with 3/8" impact. Its seems to me that the original hardware probably had some sort of spacer or rubber in between the plate and the subframe. Without something to space it it will ride on the bottom of the rack. You pretty much have to do this for spacing if nothing else.
    Ok so the back is pretty much done and ready for plate. Now the front. I took my gravel shield down first. Then I used a screw jack to position the skid plate and bolted on in the back.
    Now that it is in place where it needs to be take a drill and drill each front hole through the core support using the skidplate as a guide.
    Drill both sides. Make sure they are big enough for your bolts. I used same bolts in the front as I did in the rear. Just put the bolts in through the little holes in the core support like this one, then again use dental pick (or your finger since these holes are larger) and magnet to pull em through. I also took this oppurtunity to douse my radiator mounts and lower core support with rust converter. Damn yankee cars.
    I didnt take a picture but I used lock washer on head of bolt before I put it in and I also double nutted these bolts to keep them from moving. This presents a very unique issue. These were meant to be held on with a bolt going through a captive nut. The design of the plate like many others has catch tabs on it so its easier to take off. To be able to work with the bolts you have to bend the tabs up. This is not a big deal to me as the plate only weighs about ten pounds so taking off isnt going to be that hard. I just took a large pair of channel locks and bent the tabs out of the way. They also wont be in the way of anything else so you can just leave them like this.
    Thats pretty much it for getting the mounting set up. Next I took the used plate out and washed it good with dawn. Then shot it with a coat of rubberized undercoating. It had a few previous shots on it but still in great shape. I more or less did this to prevent rust and see any new hits.
    Next I just lifted it up and mounted it on the car. Came out great and gives me a little piece of mind on these terrible streets. Oh I used a flat washer and lock washer under that when I mounted it.
    Here is how it looks on the ground on my car. My car is pretty low in the front. Clearance is still pretty good but I did take the shittiest streets on the way home and managed to hit it twice. I am talking about some massive 8-10 inch drop dips though.
    Gratuitous picture of the whip....Also gives idea of ride height.
  • 3ionCa
    • Feb 2014
    • 314
    Oh wow, very cool DIY. Was this really a stock option on e30s?
    • jhaurimn
      • Nov 2012
      • 2224
      Thanks for posting. Pretty straightforward.
      Current:
      1989 325i
      1988 M3
      1987 325ic
      Past:
      2001 330ci
      2001 M3
      • mpowerful
        • Jul 2013
        • 1273
        Yep these were stock. Dont know what cars they came on and or if it was optional.
        • henryki
          • Jun 2013
          • 960
          I need to invest in one of these ASAP. My oil pan has suffered a few speed bump impacts since school started up again. Damn M20's and their low oil pans... DAAAMN!
          • CabbE30
            • Aug 2009
            • 2358
            How much did this run you? Trying to determine whether it is more cost effective to just get an aftermarket pan vs this one. Cool that it's OEM nonetheless. Do you have a part number?
            • mpowerful
              • Jul 2013
              • 1273
              I dont have the part # unfortunately. Maybe ill remember to take a pic next time i take it off. I paid 80 for it. More normal price for used is 150 area and pelican or bluntech or someone did list them for sale at around 200-250.
              • Bearmw
                • 1323
                I like that the factory skid plate allows a lot of air flow to the oil pan. Some aftermarket plates decrease air flow resulting in a higher oil temps.
                • chloecamila
                  • Mar 2014
                  • 1
                  For your train and so I'm making sure that they have like squashes and and other things that have a good carbohydrate value but I'm not true I have shut down there inflammation UPS and all the things Original Garcinia Cambogia that got going on there and I'm not a huge dairy percent I pretty much only do cheaper and I do on if I do my home made yogurt those are pretty much my only dairy things now you have those people that are vegetarian vegan yourself himself and I do dairy and so they do have water drains cue for grades so you can take water and different things like that that you can actually make cheaper from those things for those that are better train I've even heard I've even heard of for I'm not too familiar with a butt some cultures have even fermented coconut oh yeah you can I've actually seen chiefer with Sun with the actual use the coconut now it takes one that China has a different spin on it yeah it's actually a relief I have tried all man out that's what I want to try and see how that now makes a home made almond milk and then see how that as because it does have the facts actor that's the biggest thing is we're using where impossible stop that isn't it there are benefits especially for CM got they've got that's why I like that over water I would rather see someone you know to a coconut milk or done and that is because you need that fact that plays a role and going in and sealing up got where things are permeated definitely also people need.
                  • ///M42 sport
                    • 3952
                    still have your pics??
                    • mpowerful
                      • Jul 2013
                      • 1273
                      I need to reupload them. I will soon.
                      • ///M42 sport
                        • 3952
                        Yea if you look at the oem design the whole thing is engineered to be beefy. I run one on my 325. Well worth the cost vs the aftermarket ones which are usually flat pieces of aluminum
                        • E30 Memorial
                          • Jan 2005
                          • 315
                          Any chance you still have the photos?
                          Steve
                          '89 332i
                          '90 M3
                          '01 530is
                          '24 MC JCW
                          '13 ZL1 Camaro
                          '18 RAM 3500
                          • ianr98
                            • Jul 2015
                            • 4
                            Part Number
                            I believe this is the part number for the OEM skid plate (found on realoem.com)
                            51711929451
                            Front Aggregate Protective Plate
                            • nosh
                              • Sep 2015
                              • 15
                              have one of these lying around, wondering if you still got the install pics?
