Windshield Wipers Troubles
  • MT3CH
    • Sep 2013
    • 78
    Only one of my windshield wipers is broken. It doesn't move on any of the settings.
    Any help?
  • TheMtechnique
    • Jul 2013
    • 197
    Pics?
    1991 325i Mtechnic : : 1995 Jeep Wrangler : : 2008 Audi A8l
    2016 Triumph Scramber : : 1970 Honda CL350 x2 : : 1974 Honda XL 350
    1975 BMW R75/6 : : 1946 Ben Hur Jeep Trailer
    • DRTSRFR
      • May 2008
      • 1836
      Pull the wiper and arm off of the side that's not working. Turn on the wipers...
      If the splined shaft is rotating you have a stripped wiper arm. If the shaft is not moving, you have a broken linkage.
      Suspension tips here...
      http://www.r3vlimited.com/board/album.php?albumid=757
      • Stevoyayaya3
        • Aug 2013
        • 315
        Same problem here lol been to lazy to take it off and I didn't wanna break anything either
        • Stevoyayaya3
          • Aug 2013
          • 315
          So does the wiper arm just pop out?
          • davvik
            • Dec 2013
            • 49
            I haven't taken the wiper arms off of my e30, so I don't know for sure but most cars have a nut at the bottom of the wiper arm. There is usually a small plastic cover that covers only the nut. It just pops off.
            Sent from my SGH-T989D using Tapatalk
            • dereliiict
              • Jun 2013
              • 748
              Sometimes the nut backs off and all you have to do is tighten it down.
              You pull the plastic cover at the base of the arm off. Pry it gently toward the end of the arm. The nut is then exposed. Sometimes the arm is a little stuck so you have to use some force.
              Derek-
              • Mica Nava
                • Mar 2014
                • 1
                If your windshield wipers aren’t operating properly and clearing the glass thoroughly, this could be because they’re bent. That can happen for any number of reasons, although the main one is vandalism. The simplest solution is to try and straighten out the windshield wiper arms when this happens. This won’t always be possible, and even when you do straighten them, they will never be exactly as they were when they left the factory. In the event that you can return them to a satisfactory condition, you’ll need to buy new windshield wiper arms and install them.
                CAR OBD2 SHOP
                • MT3CH
                  • Sep 2013
                  • 78
                  That was the problem, thank you!!
                  • meanEG
                    • Oct 2013
                    • 562
                    How the fuck does this thread get posted but I can't get a real DIY posted that I took the time to make. WTF mods?
                    Looking for late model fogs, E39 Fog lights, cool cheap 17 5x120 wheels.
                    • paynedav001
                      • Apr 2014
                      • 10
                      So my windshield wipers just stopped working, I was driving with both of them on as fast as they will go (it was pouring) then they both just stopped suddenly. It has been three days and they still dont work, ideas?
                      • paynedav001
                        • Apr 2014
                        • 10
                        nevermind found out whats wrong. The little arm came off at the ball and socket spot
                        • Bahn360Photo
                          • Jun 2015
                          • 201
                          my windshield wipers work on and off, cant figure out why, any help?
                          • Dirty325ix
                            • Sep 2012
                            • 689
                            Need a little more info....if it works perfectly and just randomly cuts out at times it may be a loose wire
                            otherwise it could be a broken windshield wiper regulator (located next to your fuses)
                            • Nick_S
                              • Apr 2011
                              • 3658
                              Do they sometimes turn on on their own? I was having issues with mine working intermittently and whenever they wanted. Ended up replacing the whole stalk with a used one from a member on here. Fixed the glitch.
                              91 318is M50 swapped
                              05 Honda Pilot
                              24V swap thread
