How To Guide - E36 Steering Rack Swap
  • swooper
    • Jun 2007
    • 156
    #286
    Well, I got the steering rack out and converted the knuckle. FYI, I used the 7/16 bolt and had to enlarge the hole where the grounded rivets were in order to get the bolt through the knuckle.
    Getting ready to install the new E36 rack and noticed that it has cooling lines. Should I install the rack with the cooling lines?
    • swooper
      • Jun 2007
      • 156
      #287
      Originally posted by David325is
      We live in America and America is still stuck on using the wrong unit of measurement.
      I used two M10 x 50 hex head bolts. FYI, I had to enlarge the holes where the grounded rivets were removed on the steering knuckle to make them fit.
      I used the 7/16 inch bolts and had to enlarge the holes in the steering knuckle too.
      • swooper
        • Jun 2007
        • 156
        #288
        • David325is
          • 194
          #289
          Originally posted by swooper
          The E36 rack that I bought has cooling lines still attached. Can I install the rack with the cooling lines? Should I? If so, is there anything that I need to do?
          You will need to remove the cooling line (metal coil thing) because it will run interference with the oil pan. Ask me how I know. It isn't necessary in our (e30) case anyway.
          • swooper
            • Jun 2007
            • 156
            #290
            Thanks. That's what I thought might be the case, but wanted to confirm.
            • Kingb
              • 928
              #291
              So I read through over half of this DIY but what locking tabs do you use? The old E30/36 ones or do you use new ones and for which car e30 or e36?
              never mind I found the answer but are there any of the already spaced rebuild knuckles available??
              Originally posted by Nicademus
              My car beats off to that car. :bow:
              • David325is
                • 194
                #292
                AKG motorsport sells modified steering knuckles. Go to http://www.akgmotorsport.com/e30products.html and scroll to the bottom of the page.
                • enzo
                  • Jul 2008
                  • 73
                  #293
                  What part number are you guys using for the replacement E36 racks, specifically the Z3?
                  Realoem shows 32131095575 for the Z3, but I was sent 32131469273/32131140828 from BMA.
                  Now: 1991 318is Diamond Schwartz ;)
                  Then: 1990 M3 Brilliant Red (sold) :(
                  Then: 2002 330i (sold) :grin:
                  • RobertK
                    Kicked cancer's ASS.
                    • Jun 2005
                    • 5864
                    #294
                    You can use either locking tab. The E30 tabs are cheaper so I usually go with them.
                    I also rebuild them as posted here..
                    • Lof8
                      • Oct 2006
                      • 2827
                      #295
                      Is the part # for new locking tabs in post 1? am I missing it?
                      S50'd
                      Originally posted by TDE30
                      What is this faggy shit I have happened upon?
                      I can always live in a M3. Can't M3 a house.
                      • 318idol
                        • Oct 2007
                        • 18
                        #296
                        Rack-to-Frame spacers & Tie Rod End Questions
                        Steering swap gurus,
                        My e36 rack is on the way for installation into my 1991 airbag 318i. I noticed that it appears spacers are used when mounting the rack into the frame? Why? Are the e36 rack mounting bosses narrower/thinner than the e30 models?
                        I noticed that some installers have simply stacked washers -- some on the bottom, some on the top -- to slightly move the position of the rack for clearance. I like there flexibility of this solution, even if it is, ah, less elegant. ;-) Thoughts?
                        Are the BMW OEM spacers used on stock e36 installs? Just curious...
                        And what is the correct part number for the BMW spacers.
                        And, finally, my rack is coming complete with e36 tie rod ends? Are they a direct fit? Any mods required?
                        Sorry for being so anal, but I don't no surprises.
                        Thanks, Gary
                        • dude8383
                          • Jan 2005
                          • 10387
                          #297
                          You can use E36 tie rods (inner and outer).
                          Not sure how to answer the answer stuff but you do bring up an good question about the washer placement.
                          • Lof8
                            • Oct 2006
                            • 2827
                            #298
                            I need help with this part #, nothing on realoem. preferably the e30 locking tab if its significantly cheaper.
                            S50'd
                            • Spinning Tires
                              • Feb 2007
                              • 283
                              #299
                              I don't get it. I put an e36 rack in an airbag and a non airbag car and didn't have to modify the shaft plate or joints in either case. Most work I had to do was cut the splines comming out of the firewall like an inche shorter in the non airbag car. The other car was direct bolt up except for the spacers on the crossmember
                              First: 1984 318i
                              Second: 1987 325
                              Third: 1987 325is
                              Current: 1990 325i (Soon To Be 335i)
                              • Spinning Tires
                                • Feb 2007
                                • 283
                                #300
                                The benefit of the washers is you can move the rack ups and down to prevent bump steer. The tie rods should be straight across level with the rack when the car is on the ground
                                Thanks, Gary
                                First: 1984 318i
                                Second: 1987 325
                                Third: 1987 325is
