Originally posted by Surtr
View Post
How To Guide - E36 Steering Rack Swap
'86.5 325eis Track Ho | '08 128i DD | '04 Silverado Tow Vehicle
or. if you dont have an airbag steering column and there is just a short splined shaft sticking out of the firewall you can just cut that shaft an inch or 2 shorter and you wont have to worry about taking the joint apart and putting spacers in itFirst: 1984 318i
Second: 1987 325
Third: 1987 325is
Current: 1990 325i (Soon To Be 335i)
Originally posted by Nic01101011 View Posthey - is your car an airbag car?
ill be doing an e36 swap in the near future as well.'07 Female Miniature Dachshund, Long Hair Edition, Red.
Mods so far: Reproduction delete kit, biweekly nail shortening.
(Pics hopefully coming soon)
Originally posted by Nic01101011 View Postit was a pain finding a suitable rack, I found a guy parting a 95 M3 in Sac. Ill be picking up the rack next week
Does anybody know what part # 32131140828 is from?
Edit: I guess it's from a Z3 M and it's the same 3.2 LTL as other E36s.'07 Female Miniature Dachshund, Long Hair Edition, Red.
Originally posted by Surtr View PostOK, thanks. I'm kinda confused as to why washers can't be used as spacers on the steering knuckle, too. I guess I can come up with something.
pics of my solution:
Originally posted by SkinnyVT View PostMy only concern with using washers on the knuckle is that it might introduce some additional flex.
Originally posted by Surtr View PostThat's pretty sweet. Mind giving the measurements of that? I'm going crazy trying to figure something out before next weekend :-\
I believe the actual spacer section is 0.55" [14mm].sigpic
Originally posted by SkinnyVT View PostI would if I had them written down, I'm not pulling it out of the car to measure. I machined it with the steering knuckle sitting next to me and just measured when I needed to without writing dimensions down.
I believe the actual spacer section is 0.55" [14mm].'07 Female Miniature Dachshund, Long Hair Edition, Red.
Originally posted by Surtr View PostAh, thanks for that. I don't blame you for not wanting to take it out. Now all I seem to need is a rough estimate of the outside diameter.sigpic
I just finished the swap without spacing the knuckle. I just cut away some of the sound insulation from the firewall where the column comes out. Then I slide the knuckle on further. I also slid it down further on the shaft coming from the rack. I took the bolt out, slid the knuckle down as far as I could without creating any binding, then smacked the bolt through and tightened it up. I did have to take a little metal out of the upper knuckle because of the slightly greater angle, but it sounds like everyone has had to do that.
I used washers to fill the gap when mounting the rack, and put one of them under the rack to lift it slightly. I used the E30 high pressure hose and reversed it, and it fit with no bending.
All of my techniques/ideas came from this thread, I had no original ideas. Just confirming that this worked for me.
btw - 88 325ic 06/88 build date - no airbag
