How To Guide - E36 Steering Rack Swap
  • Cloudbase
    • 1795
    #586
    Originally posted by SoEm0
    You will need e36 ends for that rack. They will bolt to the spindle.
    Thanks. So order E36 ends not Z3 ends? Just so it's crystal...
    JOY IS AN E30...
    • SoEm0
      • 449
      #587
      they are the same.
      CCW- when every second counts... The police are just minutes away!
      • Cloudbase
        • 1795
        #588
        Thanks...
        JOY IS AN E30...
        • george graves
          • 19997
          #589
          Just got back from an alignment. Damn. The e36 rack feels so much more modern than a e30m3 rack. It's doesn't have more feedback, but it does have more friction - much more modern feel - it feels weighted - it's great. Not light and flimsy like a Oldsmobile with too much power steering - that's about how bad the stock set up is.
          That and all new CA and Tie rods (in and out) make the car feel much more like a e46. It's tight and crisp. The smallest input to the wheel (1/32") will steers the car.
          Originally posted by Matt-B
          • Jand3rson
            • 37587
            #590
            Jesus, I can't wait to drive my car. The E36 rack, combined with all new rear subframe bushings, new wheels bearings, and the new motor... my god.
            • BlackSpeed66
              • Apr 2008
              • 618
              #591
              Originally posted by bubbajan21
              Can somebody who has a Z3 rack in their car confirm or deny the "dartyness"? I'm looking at one for my DD, but I don't want my car to be darty on the free way.
              I've had the Z3 rack in my car for about a month now. Overall, I think it's a fantastic upgrade for anyone. I wouldn't call the rack "darty" but the steering is definitely more sensitive, obviously. I do notice that the steering can "grab" ruts in the road or other broken surfaces. That may be my tires though... the car does have 15x8s.
              Bottom line, the steering response is amazing and I wish I had done it sooner.
              -Geno
              '87 325is (s52'd)
              '95 525iT
              '02 Range Rover 4.6 HSE
              '98 Disco 1
              • Sean
                • 5793
                #592
                Z3 2.7 turn rack ftmfw. I love it. Not too much on the freeway at all!!
                - Sean Hayes
                • george graves
                  • 19997
                  #593
                  ^2.7....yea...I still wonder if the z3 rack is travel limited. I *hate* 3 point turns. Did you notice a little bit larger turning radius?
                  • Cloudbase
                    • 1795
                    #594
                    I can't wait to get mine done. Along with the Z3 rack new CA's, Tie Rods, Sway Bar Bushings F&R, Wheel Bearings on all 4 corners, Subframe Bushings, Sway Bar Links F&R, Trailing Arm Bushings, Shock Mounts on all 4 corners, H&R Sports, Bilstiens, E90 Hats. Can't wait to get it all back together!
                    JOY IS AN E30...
                    • Ian Bowers
                      • Apr 2008
                      • 1120
                      #595
                      Agreed. It's one of the best things I've done to the car.
                      I can still do a u-turn on a 2-lane road with no issues. It's such a minimal difference, I've never noticed it. And the turn into my driveway is around 160-170 degrees, so if it was a big difference, I would definitely notice it.
                      • SoEm0
                        • 449
                        #596
                        Yeah mine goes in tomorrow. I won't get to drive it for a few more days while I finish up my HG and timing shit.
                        • SoEm0
                          • 449
                          #597
                          Ok, if I am just using spacers on the sub frame, do I use the furthest front holes, or still the original holes?
                          • bubbajan21
                            • 1962
                            #598
                            Originally posted by Cloudbase
                            I've got a 2.5L Z3 rack I'll be putting in this week. I'll let you know. Does anyone know the length that the knuckle spacer needs to be. The original part is no longer available. I haven't searched yet, but will do and post my results if I find it.
                            So, did you get it in? If so, what are your impressions of it?
                            • bubbajan21
                              • 1962
                              #599
                              Steering Guibo
                              Does anyone know which steering guibo to use if I'm going to replace it while everything is apart? I would think the E30 one since it's still an E30 steering column, but I'd hate to have everything apart and be wrong. Does anyone happen to have a part # for the correct one?
                              • 87e30
                                • Jul 2008
                                • 5676
                                #600
                                I re-used the one from my e30. I know there is at least one more stiff poly option out there as well.
                                (I wouldn't be surprised if the z3 guibo is the same part but I have no clue)
                                I just hate everyone.
                                No need for discretion.
