How To Guide - E36 Steering Rack Swap
Just got back from an alignment. Damn. The e36 rack feels so much more modern than a e30m3 rack. It's doesn't have more feedback, but it does have more friction - much more modern feel - it feels weighted - it's great. Not light and flimsy like a Oldsmobile with too much power steering - that's about how bad the stock set up is.
That and all new CA and Tie rods (in and out) make the car feel much more like a e46. It's tight and crisp. The smallest input to the wheel (1/32") will steers the car.Originally posted by Matt-Bhey does anyone know anyone who gets upset and makes electronics?Comment
I've had the Z3 rack in my car for about a month now. Overall, I think it's a fantastic upgrade for anyone. I wouldn't call the rack "darty" but the steering is definitely more sensitive, obviously. I do notice that the steering can "grab" ruts in the road or other broken surfaces. That may be my tires though... the car does have 15x8s.
Bottom line, the steering response is amazing and I wish I had done it sooner.-Geno
'87 325is (s52'd)
'95 525iT
'02 Range Rover 4.6 HSE
'98 Disco 1Comment
^2.7....yea...I still wonder if the z3 rack is travel limited. I *hate* 3 point turns. Did you notice a little bit larger turning radius?Originally posted by Matt-Bhey does anyone know anyone who gets upset and makes electronics?Comment
I can't wait to get mine done. Along with the Z3 rack new CA's, Tie Rods, Sway Bar Bushings F&R, Wheel Bearings on all 4 corners, Subframe Bushings, Sway Bar Links F&R, Trailing Arm Bushings, Shock Mounts on all 4 corners, H&R Sports, Bilstiens, E90 Hats. Can't wait to get it all back together!JOY IS AN E30...
Agreed. It's one of the best things I've done to the car.
I can still do a u-turn on a 2-lane road with no issues. It's such a minimal difference, I've never noticed it. And the turn into my driveway is around 160-170 degrees, so if it was a big difference, I would definitely notice it.Comment
So, did you get it in? If so, what are your impressions of it?Comment
Steering Guibo
Does anyone know which steering guibo to use if I'm going to replace it while everything is apart? I would think the E30 one since it's still an E30 steering column, but I'd hate to have everything apart and be wrong. Does anyone happen to have a part # for the correct one?Comment
(I wouldn't be surprised if the z3 guibo is the same part but I have no clue)Originally posted by z31maniacI just hate everyone.
No need for discretion.Comment
