ok, i didn't take the time to read all 600 comments so sorry if this question has been asked. let me get this straight, so the steering knuckle has to be modified/shortened to fit the m3 steering rack? is this the only modifying of existing parts necessary besides minor dremeling if there rubbing after instal?
How To Guide - E36 Steering Rack Swap
Originally posted by Heysüß View Postafter reading from page 1 to 32 I still have one question about z3s steering racks....
I'm looking to get one and a friend of mine said to make sure it's the linear one? what's the other option and I'm assuming any z3 that's not an m has the 2.7 lock to lock right? Thanks in advance! this thread is soooo helpful.
one more question Cloudbase:
so the z3 rack does NOT fit the e30 tie rods correct? BUT you CAN order just the e36 outers and that will fit? thanks again!
AND I should add now I have yet to find a dealer of rebuilt racks that doesn't charge a core price, they go from $80 to $190. most rebuilt racks i've found were in the $285-$350 range.09/1989 325i 4 Door
+M30 Swap
+Z3 Steering Rack
AFAIK you can use Z3 tie rods, E36 tie rods are just beefier-Alex
Originally posted by acolella76 View Postapparently some z3's got the 2.7 linear rack while others just got the standard e36 rack. I'm not really sure when there was a switch over from one rack to another, but just make sure its the rack you want.
AFAIK you can use Z3 tie rods, E36 tie rods are just beefier09/1989 325i 4 Door
+M30 Swap
+Z3 Steering Rack
Originally posted by Evan12 View Postok, i didn't take the time to read all 600 comments so sorry if this question has been asked. let me get this straight, so the steering knuckle has to be modified/shortened to fit the m3 steering rack? is this the only modifying of existing parts necessary besides minor dremeling if there rubbing after instal?
faaaaaak, my steering knuckle is much simpler looking than what you modified. I'll post pictures later tonight but, basically, I don't have the two intertwining looking forks where you put the spacers in it's just the flex disk and the u joints. Did I miss something in all 42 pages? Do some e30s have a different steering knuckle?09/1989 325i 4 Door
+M30 Swap
+Z3 Steering Rack
Originally posted by Heysüß View Postfaaaaaak, my steering knuckle is much simpler looking than what you modified. I'll post pictures later tonight but, basically, I don't have the two intertwining looking forks where you put the spacers in it's just the flex disk and the u joints. Did I miss something in all 42 pages? Do some e30s have a different steering knuckle?09/1989 325i 4 Door
+M30 Swap
+Z3 Steering Rack
^Airbag car - right? - You need to move the shaft over. Don't worry about the length. Should be fine.Last edited by Mikhail Bakunin; 05-31-2011, 06:07 PM.
Originally posted by Cloudbase View PostOne more question. Do the E30 tie rod ends screw into Z3 rods? If not will Z3 tie rods bolt up to an E30 front wheel assembly?Originally posted by SoEm0 View PostYou will need e36 ends for that rack. They will bolt to the spindle.
I'd hate to have to reorder tie rods.
and if the z3 rack i just got is anything to go by, it came with inners only and the "male" part is on this side now. Again, I've never done this but unless there's something big I'm missing I don't think E30 tie rod ends will go on anything from E36/Z3. Hope my way of thinking helps a bit at least.
And wow, I can't believe I never thought to ask this as well. DO the E36 tie rod ends fit into the e30's stock wheel assembly?
I just assumed it did since no one made a big fuss about asking anything pertaining to that, thanks from bringing that up Cloudbase09/1989 325i 4 Door
+M30 Swap
+Z3 Steering Rack
Does anyone running the z3 rack have issues with their signals not cancelling now due to not needing to turn the wheel as much?Originally posted by codyep3I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
2002 325xit Sil/blk. SOLD
2010 F650gs twin
