How To Guide - E36 Steering Rack Swap
Just a tip I learned today.. E36 rack, IE steering guibo. Akg kit. I was having a hell of a time getting my knuckle back on the spline. Engine in the car.
I'm by myself.. I stuck a flat head to slightly open the spines on the knuckle, wiggled it on about a quarter of an inch. Once it was on there and straight, I didn't want to use a BFH or block of wood against the entire rack. I figured any sort of force would be absorbed through the guibo or the rest of the knuckle. I removed the drivers side motor mount arm, then grabbed the handle of my jack.
Coated the end of the spline with antisieze, Set the handle right against the knuckle that needed to slide on and gave it a few wacks. Went right on easily. Slid the bolt through the subframe tabs and spacer, no adjustment needed. Once it goes in as far as it can, the holes line up.
Sent from my iPhone using TapatalkComment
Has anyone else compared the feel between an e36 vs e46 rack?
I have both and find the e46 rack feels heavier to turn compared to the e36 rack, so I am wondering if the e46 rack is supposed to feel this way or not when driving.
My 1989 e30 s52 Touring... this is Betty
My 1989 325i vert (sold)...this is Nina
My 1991 M5 (sold)... this is Veronica
Photo comparison: OEM vs aftermarket windscreen for a convertibleComment
I was not wanting to match the e36 softer feel, I wanted to confirm the e46 rack feels heavier as I prefer it.
If I want a heavier feel in my z3 rack, couldn't one possibly find a larger diameter pulley, thus less pressure, giving a heavier feel.Comment
I think you would need to change the pressure relief spring to make a big notice. At nearly anything over idle, a lot of fluid is recirculated through that pressure relief valve...Comment
Where is everyone picking up their e36 racks from? Went on bmaparts looking for one, and its very ambiguous.
http://www.bmaparts.com/ShopByVehicl...e+Unit&mode=PA
Looks like they have 2 Z3 maval rebuilt racks that are the exact same for different prices?? Confusing....Comment
I doubt it
This is still a pretty popular upgrade
I bought mine from AKG
Item - BMW Part Number - Qty - Price[/b][/u]
7/16 Bolt 2 Inches Long - - xxxxxxxxxxxx - - - - -x2 - - -$???
Bolt M10x50 - - - - - - - - - 26111226737 - - - - - x2 - - -$2.70
Copper Seals 14x20 - - - - -32411093596 - - - - -x4 - - -$0.68
Copper Seals 16x22 - - - - -32411093597 - - - - -x4 - - -$1.04
Power Steering Res. - - - - -32411097164 - - - - x1 - - -$19.50
High Pres. PS Hose - - - - - 32411141953 - - - - -x1 - - -$74.00
Nut - - - - - - - - - - - - - -72111977925 - - - - -x2 - - -$1.10
LP PS Return Hoses - - - - - xxxxxxxxxxx - - - - - x2 - - -$14.50
Do all of these parts need to be replaced? Just a curiosity.Comment
