How To Guide - E36 Steering Rack Swap
  • TimeMachinE30
    • Jun 2014
    • 3749
    #1081
    You have asked this question in a few places, the answer is no. It worked for many people. If you are fearful of it, on a case by case basis, replace it.. your car.
    ACS S3 Build / Dinan 5 E34
    • estoguy
      • May 2013
      • 1087
      #1082
      Originally posted by noahsense
      I said knuckle but I really meant flex disc/joint! Around $100 so not cheap but worth doing while everything is apart since getting it off can be a god awful pain.
      I got a used one from a used BMW parts specialist outside Toronto for $50. It was a nice clean unit.
      Getting out the old one was a bit of a pain. I would have done the engine lift thing, but didn't have one, so I did the bend-the-steering-rack-tab thing. It worked out pretty well after that.
      Estoguy
      • marcusw
        • Jan 2016
        • 6
        #1083
        Thanks, I needed to confirm cause I already have my e30 hoses ordered and it would be a hassle to reorder e36 ones.
        • noahsense
          • Nov 2008
          • 102
          #1084
          You'll find that this is a really sturdy part. I'm a skinny dude so I had to clamp it in a vise (w/ soft jaws or wood) and put some weight into it. Remember, adjust, test fit, repeat.
          • Moriglioni
            • Jul 2015
            • 34
            #1085
            Anyone have a weird steering rack like this? '93 cabrio
            Sent from my SAMSUNG-SM-G890A using Tapatalk
            • Moriglioni
              • Jul 2015
              • 34
              #1086
              Steering knuckle**
              • noahsense
                • Nov 2008
                • 102
                #1087
                [QUOTE=Moriglioni;4558992]Anyone have a weird steering rack like this? '93 cabrio
                That's just the knuckle for an airbag car, 1990-93. No modification to the knuckle necessary but you'll need to either modify the firewall slightly or build a custom knuckle.
                • djmossm42
                  • Jul 2012
                  • 687
                  #1088
                  Yep just modify the firewall, here's a good write-up http://www.rmeuropean.com/bmw-e30-steering.aspx
                  My post with a few other sources, I went with an E46 M3 rack but same things apply to all airbag cars and rack swaps.
                  Sent from my MI 4LTE using Tapatalk
                  Wheelwell
                  Shadowline Motorsport: LED & 3D Printed Accessories - 10% off for new customers!
                  LED Bulb Thread
                  R6 LED Review
                  • TrentW
                    • 2815
                    #1089
                    Speaking of knuckles...
                    Can't get the steering knuckle loose from the steering column shaft. It's been two 5-6 hour days soaking with PB Blaster, spreading the clamp end gap wide as possible, prybar between knuckle and firewall. Don't want to pry TOO hard that way though.
                    Maybe heat?
                    Search failed to uncover solutions.
                    Advice?
                    • dude8383
                      • Jan 2005
                      • 10387
                      #1090
                      heat will certainly help! try to get a chisel in there so you can spread the knuckle apart. when in doubt heat it out lol...
                      • bumada
                        • Apr 2015
                        • 305
                        #1091
                        Try a slide hammer as well.
                        1989 325i S50 swapped
                        2007 4Runner Sport V8
                        • TrentW
                          • 2815
                          #1092
                          I was actually going to buy a slide hammer, but I found an 18" long chisel that had a wider edge and since it extended down far enough below the
                          car I could get a good whack on it with the small sledge. Just needed to spread that crack open a bit more...;D
                          • mtech325
                            • May 2008
                            • 569
                            #1093
                            Hey everyone,
                            I've been working on an e36 rack swap for my 91' 318 with an airbag steering shaft. In order to get everything to work properly, I had to trim a bit of the firewall like most people. Modifying the firewall plate is a must if you keep the rack positioned with spacers on top (24v swap w/ e34 pan is too close & doesn't have enough room for any other positioning). Boring out the stock plate can work in some cases, but the boot gets a bit stretched with the enlarged opening, and the stock plate isn't left with much meat on one side for my liking. This is what led to making a new plate.
                            To help others down the line, here's some rough dimensions of the new plate that my friends were kind enough to help make. Each car is different, but a new plate allows you to keep the stock boot functioning/sealing properly. Essentially the opening is moved 10-15mm down and to the right (while looking from the driver's footwell). The new plate is a little longer on the bottom so it covers the enlarged firewall opening. I did have to put some grease in the boot/shaft area since the shaft would rub on one side of the rubber, creating an annoying squeaking noise. Otherwise it works well. Add a lick of paint and nobody will even know it's there!
                            -Joey
                            • bumada
                              • Apr 2015
                              • 305
                              #1094
                              Did anybody have to file down that first knuckle from the firewall? The knuckle was catching on itself as it spun.
                              EDIT: Oops, I guess it was covered on step 25.
                              Sent from my SM-G935V using Tapatalk
                              • TrentW
                                • 2815
                                #1095
                                So I finished the rack swap and ground down the knuckle from binding, then had it aligned. It pulls to the right pretty darn bad. The guy who aligned it asked if I centered the rack before install. The rack was rebuilt by Rack Doctor (reg E36 with new inner and outer tie rods) and looked to be centered when I got it. I measured the length of the old rack and used that length when installed the new rack.
                                Would it be possible that off-center rack would cause it to pull to one side? Aligned to E30 M3 spec of 0"-1/16" total toe.
