I need a fuel tank for the 90 325i coupe. I looked at a couple etk diagrams, and they show two different tanks. One with two holes on the top, the other diagram shows one hole.
Do they use two different fuel senders on one tank simultaneously?
Is there a year split, to tell which tank I have?
Is there a way to tell which tank I need without dropping it? Can you tell by just looking under the access panel?
Which hoses should I replace along with it?
Seems like this should be in FAQ
Thanks
Thanks
