Broken rear sub-frame bushings DIY
  • Bmwb
    • Jan 2013
    • 196
    looked around last night and couldn't find a way to remove the broken pieces of the sub-frame bushings everyone said cut it out or pound it from the top , but this was in my cabrio and you cannot pound it from up top due to it being behind the firewall , so here are some pics of what i ended up doing and it worked like a charm ,
    grabbed a big bolt that could thread into the aluminum
    than threaded it by hand a bit than used this sucker and pushed up against it and it went right in
    got a 1" open wrench anything that was thick enough and fit over the broken piece
    used alot of this
    than got a nut threaded it in put a washer so it would squeez tight and put the 1" open wrench over the broken parts and threaded the bolt in with the gun than i started to undo the bolt so it puts pressure onto the broken piece and basically pull it out took me about 5 min on each side to pull them out
    Sold Black BMW E30 325IS
    1987 bmw e30 euro part out
    1990 Bmw 325i Cabrio 2.9
    Metric Mechanic 2.9 stroker
    Holset Hx35w CXRacing Manifold
    MegaSquirt ARP HeadStuds
    OEM HG AEM Methanol injection
    20psi
