How To: Coilovers and strut tube modification (with pictures!)
  • HarryPotter
    • Jan 2010
    • 3642
    #136
    Originally posted by Mucci
    The konis are adjustable so you can control the stiffness. Both the bilstein sports and konis are made for lowered suspensions. The ground control setup doesn't require you to chop the shock tubes. Why would you think you would blow them?
    Well, just due to lack of shock travel. I will be running as low as possible. Also check out this site for a good read on konis and bilsteins.
    Autocross to Win, a technical discussion of preparing winning autocross cars.
    I just can't weld anything I don't have a welder. Or at least one good enough for the job. Or else I'd at least weld a custom perch.
    John F. Kennedy
    • Moto-Mucci
      • 2058
      #137
      Go to a shop and have them do it. That's what I did.
      • HarryPotter
        • Jan 2010
        • 3642
        #138
        True. It probably wouldn't cost much I just have class all week, so hopefully I can squeeze in somewhere.
        John F. Kennedy
        • HarryPotter
          • Jan 2010
          • 3642
          #139
          My buddies willing to weld it up for me. What size pipe do I need to slip nice and snug around the strut housing?
          John F. Kennedy
          • cbusrehab
            • May 2008
            • 90
            #140
            With the coilover kit from GC, whether you shorten the front strut housing or not, can you use the stock upper mounts or do you have to use camber plates since the new springs are a much narrower diameter than the stock springs?
            • JRKOUPE
              • Dec 2004
              • 3159
              #141
              must use plates w/proper sized mount...
              • Moto-Mucci
                • 2058
                #142
                The correct sized upper retainers come with the kit.
                • JRKOUPE
                  • Dec 2004
                  • 3159
                  #143
                  ooops,,,,thats correct. I recall the gc coil over kit has the upper spring perch.
                  • Snowmann
                    • Jan 2004
                    • 459
                    #144
                    So I didn't pan the entire thread, but where did you end up getting the sleeves and how much... I've got an interesting tid bit of info pending on where/how much you paid
                    • lonestar22
                      • Aug 2005
                      • 417
                      #145
                      if i got corrado shocks and i didnt want to install a spacer, meaning i cut 4 inches out of my housing. would that in turn cause 4 inches of lowering?
                      Originally posted by Lof8
                      Seriously. Every black wheel, regardless of spoke design, looks the same from more than 3 feet away.
                      • Moto-Mucci
                        • 2058
                        #146
                        Yes because you'd have to lower the perch 4 inches.
                        • e30pwr
                          • Oct 2007
                          • 642
                          #147
                          can someone put together a definite parts list for the G60 route with cutting the housings? I am a little lost between some of the talk back and forth.....
                          I know I need the coilover kit, spacers for inside the housings, the G60(part#?) shocks, camber kit for up top, what am I missing?
                          • Schniddy
                            • May 2004
                            • 3818
                            #148
                            Originally posted by Massive Lee
                            Yup. A more direct connection that equals to having a bigger front swaybar.
                            So, the M3 tabs not only fix geometry problems that arise from lowering, but they'll also 'stiffen' up the front more.
                            • e30pwr
                              • Oct 2007
                              • 642
                              #149
                              Originally posted by iliescu2
                              This.
                              Also, why not just cut the tube 4" and eliminate the spacer? It would go a lot lower.
                              from what i understood, it will elongate the shocks life my giving it the same length of travel.
                              • Schwarz325
                                • Aug 2009
                                • 487
                                #150
                                what are those D shaped metal rings used for that come with the sleeve kit?
