How To: Coilovers and strut tube modification (with pictures!)
If you do end up going with shorts down the road, you will have to cut the tube to match the insert's length. If you don't, and just add many spacers under it to compensate height, you will be back in the same position as Bilstein Sports.Comment
440/5xx. Not sure what the rears are anymore(long story).
Changing it to 550/626 soon with the short inserts.
If you're used to low and stiff, my original rates are totally DDable.
eg: girls don't complain.Comment
haha ide want to be stiff. like 550/625 would be cool. but i also dont want to push it with the setup..
stiff isn't a problem. specially if im going lower, and stiffer is better with a female passanger]Comment
To be confirmed, but the 84-85 318i/Eta had the smaller inserts. Then it got to 51mm in 86. I suggest checking with www.RealOem.com
BTW I got your PM buddy.Brake harder. Go faster. No shit.
massivebrakes.com
Thanks Lee I will check.To be confirmed, but the 84-85 318i/Eta had the smaller inserts. Then it got to 51mm in 86. I suggest checking with www.RealOem.com
I appreciate you providing the link didn't really know where to look on that one.
Cool ya I put my name down!sigpic-Thanks warrenComment
Lots of misconceptions in this thread. Too many people spread these rumors or ideas around with little to no first hand experience.
You do NOT have to section your strut tubes with stock length bilstein sports. If you shorten your strut tubes you will need shortened shocks as you wont be able to fit any stock length shocks koni's, bilstein or otherwise.
Bilstein sports are just fine with coilovers as long as you run moderate rates. I'm running 450/650 and the ride is stiff but not bouncy. I've been driving the car daily since april, not a hiccup.
Lastly, for those going back and forth on whether or not to go the conversion, JUST DO IT! It all makes sense once you take your old assembly apart and lay everything out in front of you. And don't cheap out on shocks, they are THE most important part of the setup.Originally posted by ebelementsAlso, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
I am about to go ahead and do this project next week...but I had just one question -
Why just cut off 1"? Wouldnt 1.5" or 2" allow for more travel. I understand you would need to set the coilver higher to obtain the same height, but where is the optimal amount to cut off?Comment
where would you get the adjustable sleeve? and how much?sigpic
1985 325e - wrecked :( (being fixed and full paint job)
http://www.r3vlimited.com/board/showthread.php?t=197989
the horrible day
http://www.r3vlimited.com/board/showthread.php?t=210850
1991 318i - in process of being made a DD
http://www.r3vlimited.com/board/showthread.php?t=219793Comment
thanks ill check that outsigpic
the horrible day
^agree. i don't get why you guys need 3" of spacer when you can just cut 4" off the housing and throw in a G60 shock.then screw in the shock holder to hold down the adjustable perch. then adjust your spring higher to make up for the lost of 4". that way the spring is preload or so what close to it.Originally posted by iliescu2This.
Also, why not just cut the tube 4" and eliminate the spacer? It would go a lot lower.Comment
