HOW TO: Wrap your car
  • SweetLew
    • Nov 2014
    • 70
    Disclaimer: I am not a professional, I learned this on my own and have learned how to do a lot of what is mentioned below from professionals. That being said, it's very straight forward. Vinyl wraps are just like putting on a giant sticker, and it'll take a lot of patience.
    I've gotten a lot of responses and messages about the wrap I did on my car. After a few people suggesting a full writeup, I finally got around to it. :up:
    So the original plan was to have it painted, but with the cold winters in Utah (and this being my daily driver) I was afraid of what the temperature might do to the fresh paint. Also, for those who live in Utah or nearby, you may know that Utah roads have been under construction for about as long as I can remember. Rough roads and gravel didn't sound like a good idea on a new paint job. So I wrapped it.
    Materials list:
    • New microfiber wash mitt and drying towels
    • Dawn dish soap
    • 40-50 ft. of vinyl wrap (for details, please read below)
    • Two squeegee's
    • Sticky back felt or soft material to wrap around the squeegee (reduces friction)
    • Denatured alcohol (in a spray bottle)
    • Windex
    • Heat gun
    • Razor blades
    • Friend (optional, but makes the job WAYYYYY easier)
    Prep:
    This is a good opportunity to do any bodywork before you wrap it. Some people will do the whole filling and sanding dents which is a good way to go. Personally, my car was in really great shape structurally. The paint was just really bad and the clear coat had almost faded completely on the roof and trunk. So I had the entire car PDR'd (paintless dent removal), and sanded the rough areas where the clear coat was peeling with 1500 grit sand paper.
    The key to a good looking and long lasting wrap is making sure the car and your work area are 110% clean and warm (I can't stress these two enough). I would recommend that the surface of the car be between 60-80 degrees and out of direct sunlight. (I would hope that it's self explanatory to not wrap your car outside.)
    A good start will be to wash the entire car with a standard dish soap (I used Dawn). You'll want to remove any contaminants, dirt, and any wax coats that are still on the car. Even though it's being wrapped, I used a couple new microfiber wash mitts and the two bucket wash method to keep all the panels in the best possible condition. Make sure to REALLY focus on washing areas you normally wouldn't:
    -Door jams
    -Gas tank cover door and all around the gas cap
    -Pop the hood and get every crack and crevice around the fenders
    -Scrub under the fenders
    And anything else you find along the way...
    Next, get the car as dry as you possibly can. Wipe everything down and double check that you didn't leave any dirt anywhere. I did this, which isn't completely necessary, but then letting the car air dry for 24 hours before you begin wrapping (parked inside).
    Now depending on how crazy you want to get, you can remove most of the panels to make sure they are wrapped correctly. I didn't want to do that, so I only pulled off the front and rear bumpers and the rear spoiler.
    Application:
    I picked up 40 feet of 3M 1080 Series, color is Gloss Anthracite. I messed up on one door and ended up having to redo it, in all reality I used more like 50 feet total. So make sure you get extra material to account for mess ups.
    Right before you're about to start wrapping the car, give it a good wipe down with the denatured alcohol. Do it just as you would clean a window or mirror with it. Make sure it's dry and you can start laying the vinyl down!
    This could be a whole separate DIY just on how to apply/install vinyl on your car. This will require a little extra research on your end, Youtube videos are a great resource to see the best techniques. But basically you'll want to cut the piece for the panel you are wrapping and leave about 2" extra on each side to make sure the panel is completely covered. Lay the piece down straight and with the least amount of wrinkles you possibly can, then start in the middle and squeegee all the wrinkles and bubbles out.
    I wish I got more pictures during the process of wrapping, but this is all I ended up with.
    After it's all laid down, make sure you go back over every panel to reheat and squeegee it again. The 3M 1080 series has an adhesive that is activated by pressure, so make sure to really seal it down. DO NOT wash the car for about a week immediately following the application.
    Washing/maintenance:
    DO NOT use a pressure washer on the wrap, I made that mistake and I had to re-wrap an entire door because a piece came off. Other than that, washing it it pretty straight forward. Remember that vinyl can scratch, similar to paint, so take care of it just like you would a new paint job.
    Keep it out of the sun as often as you can. Just as the sun fades any other material/finish, it will fade the color of the wrap much faster.
    You will also start to get some little corners and pieces that come up and won't stick back down. DO NOT try to make them stick back down. Once a corner or edge lifts, it will never stick back down the same and will continue to lift the rest of that panel up. Lifting is generally very normal, just make sure to cut those pieces off with the razor blade. It's better to have a small seam if you need to recover that edge rather than have to re-wrap an entire panel.
    Other than that, a good wrap will last you 3-5 years and still look rad. It's a great investment and awesome for the price and reversibility. People are constantly amazed when I tell them the car is wrapped because it looks like paint. So I highly suggest going with a high quality material like 3M, Oracal, Hexis, etc.
    Thanks for reading! If any pros out there have more suggestions or see something I missed, please leave a response and I'll do my best to keep this updated.
    Finally, some finished shots:
    Quick before and after of the roof-
    Download the WheelCo App! https://itunes.apple.com/us/app/whee...046704912?mt=8
    Build Thread: http://www.r3vlimited.com/board/showthread.php?t=344312
  • iwantspeed
    • 3164
    Wow. Nice work man
    Project
    Parts for Sale
    Feedback
    YouTube Channel
    • Gatts
      • 24
      Nice job on the write up. Posting here, as well as your R3V post on Facebook. I too wrapped my 240 Gloss Anthracite back in 2013. So far it has held up well. Love this color, and can't beat the price for the end result. I too made similar mistakes as you did and had to order about the same total amount. The only item I'd recommend you adding to your thread is to post heat the wrap once it's on the car to roughly 180 F to ensure it doesn't lift out of the recessions, and improve the adhesion everywhere else. Some opt for using the 3M adhesion promoting primer, but I speak from experience in saying that it's a bitch to remove any wrap you lay on any parts primed with that stuff. So re-wrapping 6 years down the road would be a pain in the ass.
      I'm curious, where did you run the seem for your roof? I'm in the process of converting my E30 to late model bumpers, and will be wrapping them once finished to a color that I got from Oracal that closely matches the Zinno that's on the car now... then I'll be wrapping the rest of the car as I square away the body.
      Again, nice job!
      • lambo
        Captain Scene Points
        • 10953
        Cool stuff. I'm thinking of wrapping my car too some time soon.
        • VicE30
          • Sep 2015
          • 66
          How did you get the pillars ?
          • Justen
            • Feb 2016
            • 87
            Beautiful work. If you don't mind me asking, how long did it take you and a friend to do the whole car? And how many times did you cuss?
            • george graves
              • 19998
              Nice post OP! But, I can't see this being anything more then the PITA that it looks like. And of course, it's going to bubble, peal and wrinkle over time. 3 years? Well - unless you use high end 3m stuff, 1 year?
              Granted, cheaper then a paint job.
              Originally posted by Matt-B
              • smashervt
                • Feb 2016
                • 29
                Pretty new to the E30 scene but family has a print shop and Ive done my fair share of wrapping. There is no reason for the vinyl to bubble or wrinkle. 3M is a brand name and there are plenty of other vinyl companies that are cheaper but the same quality. Wrap does fade just like paint that it why its a good idea to wax the car. It makes the wrap last much longer if you do a wax. And pealing does happen in corners but that is why you try to clean behind the panels so it will stick longer. Ive seen wraps last 4 years. Worth it if you know how to do it yourself. Better to do it with a friend.
