13 Button OBC Tricks & Easter Eggs
  • Todd Black 88
    • Oct 2007
    • 3449
    #106
    Remove radio, remove obc, grasp bulb pack and pull it out. Install new bulb pack, and reassemble.
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • acefreely02
      • 19
      #107
      can some one tell me how to set the clock on my 13 button. when i hit time nothin happens
      • naplesE30
        • Nov 2007
        • 1836
        #108
        Damn I wish the 318is came with the 13 button obc
        • yoni
          • 468
          #109
          if you read the whole thread... you wouln't have to ask that...
          check http://www.strictlyeta.net/technical/obcfunctions.html for instructions
          • motorsports_3
            • Mar 2007
            • 1058
            #110
            How the hell do you set the date in these things. It only has 4 availible numbers. What if it is 12/16/09?
            I get to this point but cant get it to stay?
            • dude8383
              • Jan 2005
              • 10387
              #111
              dude this car is from the 80's.
              the breakdown is MMDD, there is no year there.
              that configuration works only if you have it set to American units or imperial...not sure but the manual has a rather good explanation on how to set up things like this.
              • motorsports_3
                • Mar 2007
                • 1058
                #112
                Thanks, lol it makes sense now. The douchnozzle previous owner destroyed the manual. I could check how to reset it online though.
                • oldskool3
                  • Mar 2005
                  • 401
                  #113
                  Does anyone know how to get the time to show up every time you start the car. I have the time on but once I shut off and re-start the car the temp (which is fucked) shows up and I have to switch back to time. So I want to get time to always show when the car is started. Anyone know if this is possible??
                  Photoshop by O 16581 72452 5
                  • Unearth078
                    • May 2008
                    • 2623
                    #114
                    lol
                    Originally posted by ryno
                    I was messing with the code button and wondering what it was the other day. Good thing i stopped..
                    i did the same thing.... after reading that had the same reaction.. haha
                    Originally posted by Lof8
                    4 doors allow you to transport more whores.
                    therefore, their value is much greater.
                    Down to: 89 aw2 332i/4/5 , 70 Sahara 2002
                    • delfin
                      • Nov 2007
                      • 1064
                      #115
                      Replace the thermostat.
                      Advanded Delphin Division
                      My e30s: 1987 325i/1994 318iT
                      • oldskool3
                        • Mar 2005
                        • 401
                        #116
                        Re-read post.
                        • Rocla
                          • 922
                          #117
                          Re-read post.
                          You can't get it to go allways to time, if outside temperature is less than +3c, while it's higher it will go to function that was used last.
                          Replace the thermostat, it the closest solution.
                          Current:
                          BMW 320i 2d 2.0 m20 -88
                          BMW 325i Cabriolet 2.5 m50 -88
                          BMW 316i touring 1.6 m40 -90
                          BMW 320i 4d 2,2 m54 -01
                          • 87Blue325iC
                            • Apr 2006
                            • 1111
                            #118
                            Move somewhere warm and it will stop going to temp on start up
                            Aaron
                            • E30 Cabrio
                              • Oct 2006
                              • 1954
                              #119
                              Replace the temp sensor which is located at the drivers front corner of your car.
                              Also as mentioned, if it is 37 degrees F or below outside, the OBC will default to display the temp to warn you of possible black ice conditions.
                              1988 5 spd.Cabrio/Lachs Silber/Black Leather/123k/Dealer Serviced & Maintained by both PO's
                              Clarion DXZ785USB HU, BBS Wheels, Leather e-brake handle & e-brake boot, Mtech 1 Wheel, Maplight Mirror, Performance chip, Rear Headrests.
                              Previous E30: 1986 5 spd. 325es/Delphin Gray/Black Leather/191k
                              • oldskool3
                                • Mar 2005
                                • 401
                                #120
                                Thats why. My temp always reads -30oC. Thanks
