DIY: How to swap your E30 differential (video)
  • Styleprojekt
    • 287
    This is a video on how to swap your differential. We tried to be as clear and straightforward as possible, but obviously are not trained professionals. Use your best judgement when working on your car.
    Tools needed
    - 19mm Wrench
    - 17mm Wrench
    - 3/8 Ratchet
    - 19mm Socket
    - 8mm Allen Socket
    - small Pry bar / Thick Screwdriver
    Due to the difference in 318i/325i/325e manual/auto, as well as different model years, some of the bolt sizes may be different.
    We recommend using new bolts and always torque your parts to spec
    Here is the video:
  • Phillipsaur
    • Apr 2016
    • 1
    That was good information. I sub'd.
    • Regnar75
      • Sep 2011
      • 483
      Very nice. Just did this job last week.
      • 17sd
        • 158
        Excellent video.
        Subscribed on Youtube.
        • sonomabimmers
          • Dec 2015
          • 802
          great video i like how you guys show yourselves getting on each bolt a lot of videos will just tell you and not show them cranking at least one of each different bolt. will be on the lookout for more vids
          i love bmws
          • kronus
            • Apr 2008
            • 13029
            FYI the only difference between all e30 model years is sometimes the half shaft bolts are e-torx instead of internal hex. Everything else is always the same across all model years.
            cars beep boop
            • kronus
              • Apr 2008
              • 13029
              nice video though! have been enjoying the build vids.
              cars beep boop
              • Styleprojekt
                • 287
                Thank you for the info! We just put that in there to protect ourselves so that if someone somewhere in Malaysia with an 84-316i-RHD-backwards-facing-Getrag-roofline-slicktop-32-Valve-Rotissery chicken E30 happens to have a different bolt size on their differential, that they don't cuss all over our comment section because we told them something wrong. Its easier to say, double check your bolts and specs ;)
                • Old city bimmer
                  • Jun 2014
                  • 1114
                  yep have been there swapping a diff. not a fun job at all. I had one thread actually strip. had to re-tap it again.
                  323i MTEC1
                  Z3 coupe
                  E60 M5
                  • Lkp_318is
                    • May 2018
                    • 9
                    Can't watch
                    Video comes up as unavailable. Is there a repost
                    • jeenyus
                      • Aug 2011
                      • 2064
                      I don't think it is available anymore. It was originally under Salt City Euro's channel, but then one half of that team split off for new ventures and I think took some of the videos with him. This may have been one of those.
                      • Andre3127
                        • Dec 2017
                        • 291
                        Be careful, differentials are heavy and are easy to knock off a jack stand.
                        Budget E30 Parts - Used and Reconditioned parts for your BMW
                        • efficient
                          • Feb 2012
                          • 3312
                          wrong.
                          vids were lost because he didnt see a email and YouTube closed his account
                          • jeenyus
                            • Aug 2011
                            • 2064
                            Originally posted by efficient
                            wrong.
                            Ah dang. What a bummer.
                            Sent from my Pixel 2 using Tapatalk
