M20 Head Rebuild Video
  • sileighty
    • Apr 2016
    • 117
    Just wanted to share what I found. It's a video of an engine builder assembling an M20 head. Nice production quality, great lighting etc. I think it's good supplement for someone who is going to do this job, especially if you are a visual learner. :up:
    NOTE: Some viewers have mentioned a few errors in the build (e.g. missing oil drip pipe) so only use this as a supplement to your other engine building material! :up:
  • AC_Schnitzel
    • Sep 2017
    • 149
    This is great, thanks for sharing!
    JP
    WTB: Z3 1.9 lever, plastic bumpers, 19# injectors, Anthracite Cloth Sport Seats
    Current
    88 325 super eta
    00 528i/5 (daily)
    02 530iA sport
    Former
    04 525iA sport
    87 325is
    91 325i
    97 528i
    • squidrope
      • Dec 2012
      • 291
      Thanks great video
      • noid
        • 1537
        Fantastic video, I downloaded the video in 1080p in case it ever disappears off youtube.
        Two things I would have done differently:
        Used a thread chaser instead of a tap to clean the threads, and put the oil rubber plugs in the right way.
        Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
        Your resource to tools and tips: www.rtstools.com
        • LateFan
          • May 2013
          • 4428
          ^^ I had to look that up. I've never used a chaser, didn't know that was a thing.
          Found this good debate...
          http://www.practicalmachinist.com/vb...er-tap-237679/
          Your thoughts on this?
          Good video BTW. Very relaxing. He has all the right tools. I could do without the music, I just want to learn.
          • noid
            • 1537
            Taps are very sharp and are primarily used for cutting. As you run down a tap, unless you apply the exact same amount of pressure on all axis's (XYZ) at all times, it will inevitably cut more material.
            To illustrate this, tap a hole once, and put a bolt in it to see how tight it feels. Then run that same tap down the hole 20 more times and try that bolt again.
            In really cruded up situations, a tap will cut its way through where you would prefer the current threads to be cold rolled back into shape.
            Not everyone refers to them as thread chasers, some call them thread restorer.
            IMO, always use the purpose built tool for the job you are doing, if you're cutting use taps, if you're cleaning use thread chasers.
            • noid
              • 1537
              I just realized, that they forgot to install the oil pipe! (Part 11421265376)
