DIY- Rear Headrest install
  • Violet88
    • Jun 2010
    • 435
    hey, is this process the same for convertible rear seats?
    '88 325i cabbie royal blau
    '91 325i cabbie calypso rot
    '92 318i cabbie laguna green
    ~I like all my b!tches topless ;-)~
    • ohthejosh
      • 4963
      Do the rear seats in a e30 m3 have these slots to mount the brackets as well?
      SO MUCH MORE TO DO!!
      IG: ohthejosh
      LEGIT CHECK ME BRUH
      BUYER FEEDBACK THREAD
      • CabrioPunk
        • 1451
        It works for verts, yes.
        • Shadye30
          • 177
          Yes they do.. Installed a pair into my E30 M3 last month
          1988 E30 M3
          Diamantschwarz/Black
          • stamar
            • Apr 2011
            • 1362
            PLEASE
            Add to this diy by showing how to remove the headrests from a seat.
            • george graves
              • 19996
              Aren't their 7-series head rests that are fat and wide? Do they fit? Anyone know?
              Originally posted by Matt-B
              • stamar
                • Apr 2011
                • 1362
                I know the e34 head rest is exactly the same.
                • td325ic
                  • Feb 2006
                  • 779
                  Originally posted by stamar
                  PLEASE
                  Here's some DIY instructions I found on how to remove the headrest from a seat:
                  Step 1) PULL UP
                  Step 2) See step 1
                  • stamar
                    • Apr 2011
                    • 1362
                    no you need the bottom peice too dont you? is that all you need?
                    Well Ive pulled up on my headrests and they dont come out.
                    • td325ic
                      • Feb 2006
                      • 779
                      I was just giving you a hard time. Yeah sometimes they're difficult to pull out but here's two tricks I use:
                      Put the headrest to the highest position you can and then use the palm of your hand and whack them upwards (like you're giving them an uppercut but with your palm)
                      Or grab the headrest with both hands and slide them up and down rapidly. You'll gain momentum with the upward stroke and that momentum should release the headrest from the clips.
                      Last resort you can just take off the back panel and use a long flat bladed screwdriver and pry out the two metal clips.
                      • george graves
                        • 19996
                        Originally posted by td325ic
                        Or grab the **** with both hands and slide them up and down rapidly. You'll gain momentum with the upward stroke and that momentum should release the *** from the ****.
                        • jajou318
                          • Jan 2005
                          • 1023
                          Lol I'm surprised people are still using this :)
                          • ohthejosh
                            • 4963
                            ^^lololol
                            IG: ohthejosh
                            LEGIT CHECK ME BRUH
                            • ohthejosh
                              • 4963
                              Found some brackets at the yard and a 7 series with those comfy headrests.
                              IG: ohthejosh
                              LEGIT CHECK ME BRUH
                              • ZM Blue Devil
                                • Dec 2006
                                • 13836
                                just make sure you get vert/m3 headrests or non vert/m3 headrest to match what car you have. vert/m3 has no piping, others do.
                                Levent
                                %20levent@gutenparts.com
                                Ladies:
