deer dnova89...
Follow the work process of td325ic youre bound to get good results if youre patient
and follow along. I edited his instructions to be as clear cut as possible.
All red tail lights based on method used by td325ic.
1. Mask all but amber portion of your lights.
2. First spray 3 light coats on the amber.
3. Unmask and mask off reverse light.
4. Sprayed the whole light with 2 medium coats.
5. Remove masking of reverse light.
6. Wait a few days for Metalcast paint to cure.
7. Spray with SprayMax 2-part Urethane Clear Coat Aerosol over entire light.
8. Wait a few days for the urethane clear to cure.
9. Wet-sand with 1500 - 2000.
10. Polish out sanding scratches with 3M Rubbing Compound and orange foam pad.
11. Finish off with Menzerna Micro Polish and Gray foam pad.
I'll be following these directions as soon as i can pic up a nice extra set of tails.
