Water Leaks = Fix
    Thanks, but is it possible if those drains are clogged it would make my front carpets wet?
    M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
      any one
        Dougie - front carpet passenger is typically the elephant trunk. Driver side is commonly clogged grills below windshield.
        Parts Collector and Former Houndstooth interior junkie.
          Thank you! but im not sure what the "elephant trunk" is? sorry im a noob. also are you talking about the grills were the wiper is? because they arent clogged and my floor is pretty wet and is just adding to the already pretty bad rust...please help
            Clogged grills?
            Explain please, as i have found wet drivers side carpet this year.:(
            Originally posted by codyep3
            I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
            2001 silver/Blk 325 cabby. SOLD
            2002 325xit Sil/blk. SOLD
            2010 F650gs twin
              Ok … they are the air intake pleniums that are on your cowl right below your windshield. leaves and junk gets in there and traps them causing a leak.
                well i took mine off and there wasnt anything in them, i was wondering if it could be my sun roof but im not sure, i reallly need to fix this tho.
                  Where do they drain out of in there? I see no actual drains in there.
                  2010 F650gs twin
                    Does anyone have a pic of what its supposed to look like inside the grills?
                    Mine looks to have seam sealer that has dried and cracked....or some shit like it. If i pour water in there on the drivers side, i get water running into the drivers footwell from the seam area were the firewall meets the side of the car.
                    Is the seam sealer the issue?
                    The passenger side looks smooth and intact.
                    2010 F650gs twin
                      that is probably whats wrong with mine because only the drivers side footwell gets wet. could you be more specific on were this seam is? is it under the grill thing? or in the engine bay?
                        Under the grill, by the wiper linkage.
                        2010 F650gs twin
                          I have water pooling in the jack well of my car. I have no sunroof and I checked the trunk seals and replaced both tail-light gaskets. The bottom of the well looks like it has some kind of silicon sealant, but no vent hole on the bottom. Any thoughts?
                          E30 | E46 | E53 | F31
                          Collection of my DIY Guides here
                            what about passenger side leak when sunroof tubes are cleaned and elephant trunk removed?
                              update
                              ac heater core has 2 metal pipes that run through the firewall on the driver side beside the brake booster.
                              i traced a water leak when it rained to this area.
                              remove the old seal and remember which orientation it goes it, kind of a weird shape.
                              new gasket, ordered through Irvine Bmw dealer, order was sent out to Germany for the part to be special ordered.
                              new vs old
                              Project
                              Parts for Sale
                              Feedback
                              YouTube Channel
                                I traced down a 4th leak.
                                ac grommet for the ac lines on the passenger side of the car behind the glovebox, next to the hood hinge.
                                old
                                purchased a new gasket through Irvine Bmw.
                                old vs new
                                new, almost done lining it up.
                                Project
                                Parts for Sale
                                Feedback
                                YouTube Channel
