Taurus side skirts - modification and installation
Minor update today, sanded down the cutoff ends of the skirts with 180 grit, giving them a nice finished end, and rounding off any sharp edges from the cut. A piece of sandpaper wrapped around a wood block will give a good straight edge, taking down any irregularities in the cut surface. 100 grit would probably work a little faster, but 180 was all I had. Next step is getting them sanded and ready to paint.Comment
they are going to look sick on your car.Comment
Mercury Sable of the same year is the same car.
I hope to find some soon'74 2002 - Build blog at
nomads2002.blogspot.comComment
More work done today, one of the skirts is sanded, I waited on doing the other so I could get a comparison pic. And I thought these things were filthy before I washed them!
I used 180 grit paper for sanding the skirts. Since there are nicks and scratches in the skirts that go through the paint into the urethane, I sanded them down as close as I could get them, but not completely flat. For the rest of the smoothing, I'll use high-build filler primer and sand between each coat to even out the surface.
Here is a shot of the ends that were cut off, sanded down and the edges sanded and rounded off:
Then, Andrew and I attached the endcaps to the insides of the skirts. We used Loctite 2-part plastic epoxy to attach the ends. Before we epoxied them, we used the edge of a flathead screwdriver and tore up the surface of the 2 parts being epoxied, getting them good and rough. Yu can use something else, but this worked in a pinch.
We applied epoxy to the inside of the skirt and sandwiched the endcap down against it. We also made sure to get plenty of epoxy around any seam, and create a good seal.
This stuff dried solid in 7 minutes, so be sure you get the endcaps exactly where you want them quickly, because you won't have much time to move them around.
looks nice. cant wait to see em painted and mounted. i cant wait to get a set for myself!1991 318is nv m50 : brilliantrotComment
Just got a quote on the phone from the local pic-your-part yard... $30 EACH for these. That's with me having to pull them and everything!
Time to keep looking.'74 2002 - Build blog at
Originally posted by Grueliusand i do not know what bugg brakes are.Comment
Not cheap when everyone else is getting a pair for $20. They had 14 taurus there. I may stop in and yank them and see what they quote me at the door. I can always just leave.'74 2002 - Build blog at
Joe Funk -- Portland Oregon
That Guy.
03 X5. 3 liter obviously.Comment
Just went to my local pick and pull. $50 for both, if I pull them.
I saw a good half dozen, AND a mercury sable set that was actually a little more agressive looking, wish I would have brought my camera.
hearing everyone else get them for like $10 kept me from pulling the trigger.
I'll probably pick them up next week.Slicktop City!Comment
God damn, that's ridiculous! This place I got mine from even has standardized pricing, and they were only $4.50 each.
All the junkyards in the country are probably catching on that all of a sudden, they're getting flooded with calls for Taurus side skirts, and raising their prices. Next thing you know, they're going to be $200 for a pair.Comment
