How to replicate HELLA's smoked ellipsoid technique:
  • Justin B
    Sikky Nar Nar
    • Mar 2005
    • 4273
    #91
    It probably wouldn't be too difficult, just time consuming and tedious to make your own templates that would be close enough to work. The way I'd do it is by cutting up a cereal box and taking as many basic measurements from the reflector as possible and cutting a slightly larger than needed rough cut then setting it in as you trim it little by little. Once it's pretty smooth on each side just copy whichever side is closest (if you hadn't cut them too well symmetrically) onto another piece of box and for the sides cut it a little small then add in that little ledge by the tabs by not cutting it small there. Add a tab in there and you've got yourself a rough template. Remember as long as it's close it'll do the job. All it has to do is prevent the light from bouncing all over the place inside and back out, so if it's not 100% perfect following the reflector curve it shouldn't make that big of a deal.
    • evil_twin
      • Nov 2007
      • 2965
      #92
      Originally posted by ColdAccord
      damn. i was trying to see if I could use the same template for the crosshairs
      If that what the case, you probably can. I broke the backing (reflector part) on the 3 series, and I used the 5 series. I just didn't use the projector part or the housing. But I think you can use the cross hairs.
      Paypal: vdang5@gmail.com
      Delta Auto Care
      2875-C Towerview Road
      Herndon, VA
      703.435.1375
      My Feedback Thread: Evil_Twin
      • ColdAccord
        • 5926
        #93
        cool. i also have a spare hella ellip from my e32, i wonder if thats the same size, or of any use to anyone
        Originally posted by blunt
        • mikeedler
          • 6707
          #94
          yep, e32, e34, e30 are all the same parts except the e30 has a different plastic frame that holds the lights, and the e30 has different mounting points where the adjusters mount. the lenses are the exact same, as well as the shape of the crosshairs, as well as the ellip backing part.
          • oldskool3
            • Mar 2005
            • 401
            #95
            Anybody have any suggestions as to the best method to notch the housing for the crosshairs and which tool works best? Thanks
            Photoshop by O 16581 72452 5
            • GaryE30
              • 4791
              #96
              I'd like to know this as well before I start chewing the hell out of these housings with my dremel.
              EDIT: Use a dremel with the cutoffwheel and cut from the outside inward. This will make a larger slot outside, but just a skinny short one on the inside. Works perfectly!!! Make sure you know where to dremel though.
              Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
              • RedStar240
                • Mar 2007
                • 769
                #97
                Has anyone does this replication with the smileys?
                Benji
                '90 M50 + M3 Tranny e30 - SOLD
                '99 528iT (M5 Rep bumper) - SOLD
                '03 ML350 - For Sale
                BIMMERLESS at the moment. :???:
                • GaryE30
                  • 4791
                  #98
                  Justin B posted pictures of smiley smoked.
                  • maxel
                    • Jun 2007
                    • 116
                    #99
                    Satan
                    Axel
                    BMW 320i Touring (M20B25)
                    • maxel
                      • Jun 2007
                      • 116
                      #100
                      double post
                      Axel
                      • der affe
                        Technical
                        • Dec 2005
                        • 8452
                        #101
                        my lenses were being stubborn and wouldn't come off in the oven. i heat gunned them and cracked the lenses. crap!
                        anyone know where i can get HELLA replacement lenses??????
                        • maxel
                          • Jun 2007
                          • 116
                          #102
                          BMW Dealer, junkyard, E30, E34, E32 :)
                          Axel
                          • der affe
                            Technical
                            • Dec 2005
                            • 8452
                            #103
                            PASKA!
                            i have hella H-4's (single light with high and low beam ala inner headlight delete). they are the the replacements for the sealed beam style. are they the same as the regular lenses
                            • CorvallisBMW
                              Long Schlong Longhammer
                              • 13039
                              #104
                              OK so i just attempted this too. Baked all lenses as per Jordans instructions at 350F. The plastic adjusters melted, and fell on to the oven element making a terrible smell. I lost about half of them. Then I tried to pry off the lenses, and one shattered in to pieces. THe others will not come off, they are on there fucking tight as nails. I just don't get it, WTF am I doing wrong? I'm ready to just buy them pre-smoked.
                              • Hairos E30
                                • Mar 2008
                                • 378
                                #105
                                ima try this fer'sher when i can..give u ups for sharing...
