Engine Push Start Button Install
  • JamesE30
    • Feb 2007
    • 2092
    I purchased my button from Demon Tuning in the UK, through the fabulous Fleabay.
    This is what you will need for the install.
    -Button
    -Wires
    -Standard Relay
    -and tools to splice wires
    The kit i purchased left no need for splicing as they have this fantastic product which you simply clamp onto the two wires to splice them (this only requires a pair of pliers)
    I highly recommend doing this in daylight unless you lake working with a lamp inches from you face. NOW,
    Throw away the instructions and do this:
    1: Disconnect battery from car. (safety first!)
    2: Lay out wiring loom and check you have everything at arms reach.
    3: Remove the steering wheel (not necessary but makes it ALLOT easier)
    4: Remove kick panel in driver side foot well.
    5: Locate the Plastic wire adapter attached to the back of the steering shaft, just bellow the steering wheel.
    6: Locate the Red wire (hereby referred to as "Red"), and the Black/Yellow wire (hereby referred to as "Black/Yellow") coming out of the back of the adapter.
    (The red is the Ignition Power, and the Black/Yellow is the trigger for the Starter Solenoid)
    7: Wire system as follows:
    Relay:
    #30: --> Red
    #85: --> EARTH
    #86: --> Start Button --> Red
    #87: --> Black/Yellow
    (See wiring diagram below)
    8: Reconnect battery.
    9: Turn key two clicks and test button.
    10: Cable tie all wires and neaten up everything.
    11: Mount button in desired location.
    And here are a couple of pictures of it mounted in the cigarette lighter location:
    NOTE: Most "kits" are designed to fit perfectly in the cigarette lighter hole,
    However the e30 requires a little fabricating for this particular button,
    as well as some kind of spacer (I just used some 2mm plastic, cut to shape)
    or else the button will sit down too deep in the hole.
    I hope this Thread is easy to follow. -feedback appreciated
    Thank you to StereoInstaller1 who was a huge help with this process.
    He knows his shit.
    R.H.D
    M-technic I club
  • Majikal
    • 518
    whered you mount the button? Pics of finished install?
    • StereoInstaller1
      GAS
      • 22679
      Do yourself a favor though...buy a real set of crimpers and THROW AWAY THOSE FUCKING SCOTCHLOCKS!!111ONE!
      Tiny contact points do not make a solid connection and they will not stay reliable.
      Luke
      Closing SOON!
      Thanks for 10 years of fun!
      • JamesE30
        • Feb 2007
        • 2092
        currently the button is dangling from the dash like some sort of car bomb trigger.
        I have so much shit to do for uni atm, i havn't even had time to think about the poor car.
        But i will get pics of it as soon as its done.
        As for those connectors, they're fine for now, if ever they fail, there is no issue as the key still works. It's an easy fix anyway. Splicing wires aint hard.
        R.H.D
        M-technic I club
        • Mr.sexymorningvoice
          • Sep 2007
          • 402
          ehh...knowing my luck a scotch lock would fall apart when i was trying to show it off to my buddy...just solder and heat shrink those puppies...and never worry about them
          • StereoInstaller1
            GAS
            • 22679
            Nope...never solder in a car unless forced to. No manufacturer uses solder any more, neither should you. Much higher resistance and solder ALWAYS causes corrosion inside the wire. A quality crimp using a good tool (I use Channel Lock "Wiring Pliers") make a far superior connection.
            I will agree that a shitty crimp is inferior to solder, though. Stamped steel crimpers should go in the trash immediately.
            Luke
            Closing SOON!
              • Sep 2007
              • 402
              hmm...i am assuming that since your name is stereo installer, then you should know. lol thanks for the tip. But im tellin ya, rosin core solder, or dippin the shit, i got mad skillz...haha. So then are you heat shrinking your connections, or how are you keeping your exterior connections good?
              • StereoInstaller1
                GAS
                • 22679
                as in under hood stuff? Heat shrink is an excellent option, but generally I simply use Scotch Super 33 electrical tape...the absolute god of all electrical tape. If I am working on an application where water resistance is critical, I simply squirt a gob of silicone sealant in the ends of the connector before inserting the wire and crimping. Learnt that there trick from an Alaskan installer who did amazing work.
                Luke
                Closing SOON!
                  • Sep 2007
                  • 402
                  yea...thats what my dad does, but i have found the crimp n seal connectors very handy...normal crimp on connector with heatshrink on the insulation, and it is the good kind with the glue...lol good stuff
                  • Midnight Sun
                    • Jan 2007
                    • 429
                    It doesnt still start by using the key though, does it?
                    Originally posted by Teaguer
                    Filling an Eta's tank with super unleaded will reach the cars maximum attainable performance level .
                    Aa a bonus filling the tank will also double any Eta's resale value .
                    • franco90
                      • 3185
                      give me your address so i can take your ride just kidding
                      I've always been proud of being a Marine.
                      I won't hesitate to defend the Corps
                      "Supersquad"
                      ‎"Prostitutes are a sub-category of Amusement Parks"-
                      • JamesE30
                        • Feb 2007
                        • 2092
                        ha ha ha...
                        Yes. It still requires the key.
                        R.H.D
                        M-technic I club
                        • onaquest
                          • Nov 2005
                          • 805
                          pics and/or video?
                          -Ryan
                          http://bbswheels.blogspot.com
                          • robtech
                            • Sep 2007
                            • 217
                            still need the key...
                            why do it then?
                            beware of attack squirrels
                            • browntown
                              • Jun 2004
                              • 3524
                              Excellent writeup. Just reminded me though. I think it was in the Roundel earlier this year, but one of the editorial bits was on starter buttons. I might be wrong, it could of been one of five different car mags I read. It was a funny article though, saying that the key start was a wonderful invention, and getting RID of the push start was celebrated by all. Now new cars are putting backwards moving technology in and people love it. It's all about fads.
                              I've started a push button car before, and it was cool for the novelty, but I'm sure I'd get sick of it after a while. I suppose it's because I am of a generation that didn't have to deal with them to begin with, and the last car with a manual choke in my family was when I was 7.
