Engine Push Start Button Install
  • AndrewBird
    The Mad Scientist
    • 11897
    #61
    Originally posted by e304me
    why the need for the relay?
    Um, which one?
    If you mean the one he used in the original post, it's because the pushbutton can't handle the amp draw the starter motor makes.
    • e304me
      • Feb 2006
      • 1374
      #62
      well it goes to another relay anyways right? i have a modified cig lighter as my starter button and it seems to do the job
      • DaveSmed
        • Apr 2007
        • 1406
        #63
        No.
        Interesting the cig lighter passes enough current to engage the starter solenoid. Kinda thought it might, BUT for the best reliability, you will want to add in a relay yourself. There is a chance the solenoid may need more amperage one day (maybe on a hot engine on a hot day? who knows) and the cig lighter is just going to heat the element up instead of actuate the starter.
        -Dave
        2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
        Need some help figuring out the ETM?
        • Sean
          • 5793
          #64
          Yea, I saw that video. I'd be worried that you'd melt your ashtray apart like that. The starter draws a lotttttaaa power.
          - Sean Hayes
          • e304me
            • Feb 2006
            • 1374
            #65
            Its actaully just the solenoid it powers. And i welded a bead across mine so it wont heat up
            • Axxe
              • Aug 2004
              • 3355
              #66
              The starter solenoid acts as the high current relay. An extra relay on the pushbutton doesn't hurt though, especially since most are cheap and can't handle more than a few amps.
              Keep it slideways!!
              • AL GReeNeRy
                • 136
                #67
                fyi, my cig lighter starter mod is pretty much the same as this except mine was free!! used a relay as well and instead of buying another switch, i used my broken cig lighter that doesnt stay down. so there will be no melting of any part of my car!
                1991 318is nv m50 : brilliantrot
                • DaveSmed
                  • Apr 2007
                  • 1406
                  #68
                  Damn, that works too. Good thinking.
                  -Dave
                  • AndrewBird
                    The Mad Scientist
                    • 11897
                    #69
                    Anyone got a link to this video you speak of?
                    • evil_twin
                      • Nov 2007
                      • 2965
                      #70
                      I'm not sure if this was asked already, but can you still crank the car without pushing the button?
                      Paypal: vdang5@gmail.com
                      Delta Auto Care
                      2875-C Towerview Road
                      Herndon, VA
                      703.435.1375
                      My Feedback Thread: Evil_Twin
                      • e304me
                        • Feb 2006
                        • 1374
                        #71
                        you could wire it that way but if you cut the wire you need to tap into then no
                        • Doughnut
                          • Oct 2007
                          • 869
                          #72
                          If you wire the button same as the OP, then Yes, you can still use the key to crank the car over.
                          ///Monstrosity. (OO≡≡[][]≡≡OO)
                          Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
                          • MA-BMW
                            • 209
                            #73
                            Sooooooo, anything happen with the key pad and what not?
                            • Bread
                              • Jun 2005
                              • 24
                              #74
                              I don't understand the point of the key pad when you can program a security code into the OBC to disable the starter anyways.
                              As for making your wire connections, always use solder. If your soldered joints are cracking, then you didn't do it properly. A cold solder is brittle because it sticks to the surface of the wire, rather than penetrating the strands. Cold soldering is caused by heating the solder directly onto the soldering iron and dripping it onto the wire. Good, clean wiring with the solder drawn through the strands (heat the wire, not the solder) will be stronger and conduct better than any crimp connector. Especially those cheap wire taps. Soldering your wire taps also protects the connections from corrosion. This is especially important for wiring done under the hood.
                              I've got a truck with many aftermarket wiring connections made with wire crimps over 30 years ago. To this day I'm battling the many unreliable connections from years of moisture entering the contacts causing surface corrosion between the wires. Had these connections been properly soldered and wrapped, I wouldn't be dealing with this. Hell, I found a handful of pastic wire taps under the dash of my M3 that were no more than 10 years old and they were already totally crap.
                              Plastic wire taps are the lazy way of doing electrical work. I remove them everytime I come accross one. They'll only cause you more headache in the future.
                              Jason,
                              1988 E30 M3, 1999 Ducati 996, 1971 International Scout II
                              • DaveSmed
                                • Apr 2007
                                • 1406
                                #75
                                Hmm, well, thats not entirely true believe it or not. I agree that all scotch locs should be deposited in the nearest trash can, word is these days is best connection comes from a proper mechanical crimp+silicone or adhesive lined heatshrink.
                                -Dave
