I tell you those "SQUARE HEADS" have nothing better to do then to mess a perfectly good design up due to boredom; I have no idea what that metal plate serves and this is the first one I've seen or heard of in the 12 cars I have owned all being mostly late models. It seems this is a US problem because it Canada I haven't encountered this.
Replacing the E30 Heater Core and Valve
Originally posted by CreamE30 View PostOK R3v, here's what I'm up against. Not sure if this was just a self explanatory thing, but I have an extra obstacle in my way:
The hell is this thing? It looks like there are three bolts holding it in, two along the transmission tunnel, and one under the steering wheel trim pieces:
Can I take this out? Or will it end up being the backbone of my E30 and everything will fall off my car?Originally posted by e30shmobberr View Postwtf?? never seen that beforeOriginally posted by ///digitalme View Posti saw this at the yard...on 2 cars...they were on late model cars...and for this reason i couldnt get a heater core! but the ones i saw at the yard were welded...atleast yours are held by bolts...Originally posted by T La View Postany word on removing that strange metal piece? I have the same problem....Originally posted by Ceeker View PostI tell you those "SQUARE HEADS" have nothing better to do then to mess a perfectly good design up due to boredom; I have no idea what that metal plate serves and this is the first one I've seen or heard of in the 12 cars I have owned all being mostly late models. It seems this is a US problem because it Canada I haven't encountered this.
^ exactly, just unbolt it to get it out of the way.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
I bought the 325 with a bypassed heater core, I got around to taking it out today, and it looked like only the o-rings had been leaking before, so I went out and bought new o-rings, put it all back together and its leaking from both corners of the heater core, AND from the heater valve? Has anyone ever had a heater valve leak before? Also does anyone have a diagram of which way the hoses in the engine bay are routed? Im pretty sure I have them routed right, but I just wanna be sure!1998 Mustang-Endless project
1990 325i Sedan-Needs paint
1991 318is-New project
Wow, there is a lot of people having problems with their heater cores and valves!///Monstrosity. (OO≡≡[][]≡≡OO)
Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
Originally posted by Doughnut View PostWow, there is a lot of people having problems with their heater cores and valves!
Originally posted by dillsnick View PostThat's the support for the knee bolster in air bag cars. There should be 3 bolts that hold it into the shift tunnel. They are not welded in (it might have been really dirty and seemed that way). Once you unbolt them, it's easy to move out of the way. I have two air bag cars that I've done this for, it looks scarier than it is..sigpic
Originally posted by nuk78 View PostHey guys, I also have a bad heater core, planning on changing the valve as well while im down there. Anyone know where to get the best deal on core and valve, pelican parts will be running me well over $300 for the pair, any advice would be helpful, thanks!sigpic
Originally posted by mo diesil View Postare there negitive effects of bypassing the core temporarily?
Originally posted by Ceeker View PostI'm sure you can find a good used core and heater valve on here for a fraction of the cost. Post on the wanted list.
