Rear bulb carrier for Euro Fog Lights ON THE CHEAP!
This write up shows you how to modify your current rear bulb carrier into a euro one that can accommodate the extra bulb for the fog light. I didnt want to spend 50 dollars at the dealership for one so I decided to make it myself.
Left Euro bulb carrier (part # 63 21 1 386 091) $47 @ the Dealership FUCK THAT!
Parts:
-Regular Rear bulb carrier(Left or Right) $5 @ PickNPull ($2.50 Labor Day ½ off sale:))
Tools needed:
Needle Nose
Soldering Iron
Flathead Screwdriver
Left and Right rear bulb carrier off a 325i @ the PnP for $5 dollars..
(I'm using the right carrier as my donor and modifying the left one)
Step 1: Use a Needle Nose and push one of these pins in. Once you push it down enough you should be able to pry it from the back.
Cut the metal piece that's connected to the carrier off and pull the pin all the way out. Then cut off the extra metal around the pin.
Step 2: Now we need another piece off the donor carrier. Use a small flat head screwdriver and pry this off.
Once it's free cut it off the carrier. Then clean it up by cutting off the extra metal.
Now we're ready to modify your carrier into a euro one!
Step 3: Get the bulb carrier from your car and lay it down
Step 4: Locate the metal strip with the hole in the middle and insert the pin that we removed from the donor carrier. Push it all the way down.
Step 5: Now follow that metal strip you inserted the pin into all the way to the end of the carrier. This is where the fog light bulb goes.
Step 6: Now insert that other piece that we removed off the donor carrier into the empty slot. It should just snap in place.
Step 7: Now solder up the pin and bulb connector to the metal strip.
Finished product! $5 dollar euro rear bulb carrier :)
Wiring can be found here
-Bey
