5 Speed Swap Wiring - Plug & play w/ cruise control !!!
seems easy enough. Hope it works in a week or two when i put my 5spd in. The only thing that throws me off was the mention of a "bottom" clutch senosr switch thing. What the world is that? As far as i know it the switch at the top pf the pedal only. Whats the bottom switch? Never heard of one.Now with 2.7i power!!!Comment
Works sweet!!
The Auto Harness has 5 wires on it- 2 Brown, 1 Black with yellow stripe-connected to another black wire with yellow stripe via connector, 1 black( connected to ignition switch, 1 green with black stripe( this one may vary- older models might have 2)-connected to blue wire with brown stripe.
Unplug Blue wire with brown stripe connected to Green wire with black stripe.
UNplug black wire with yellow stripe connected to black wire with yellow stripe
Unplug black wire from ignition switch.
Plug in black wire with yellow stripe into ignition switch where u pulled the black wire.
Unplug the harness that is plugged into the reverse plug- then plug in your reverse plug from the trans.
Plug in the clutch switch to the top of the pedal ( its the one that is deleted to its self with blue wire with red stripe)
This works spot on!!!! CRAZY EASY!! and clean, which I like. No ghetto hack job. Takes 5 mn if that. Thanks for the info on this. Gotta say pullin the auto SUCKED!!!! stupid starter bolts. Well worth it once its all in though. Its like a new machine. Back on topic, THIS IS THE ONLY WAY TO DO THE THE WIRING ON A 5SPD SWAP.Now with 2.7i power!!!Comment
BUMP FOR AN AWESOME TUTORIAL!!!!
Caps were needed there. This has given my car new life and i get to drive stick shift. :DComment
The last post on the first page is the correct method. Use the previous pictures that the OP made as a reference.Comment
Hmm.. I think I got it now. My friend helped me do the wiring and such when we did my swap, so I was completely confused as to what to do. I texted him and he told me whats up.
It seems I just needed to plug in my Reverse light harness to the Tranny Harness. I went all crazy and made it complicated by doing the wiring anyway.
Just gonna undo it all and see if everything still works.Comment
lol I know how that is. I finished putting in my exhaust like an hour and a half ago. quite annoying to do when there is no light.Comment
This mod is really easy once you spot all the wires that need to be disconnected. Really takes about 5 to 10 mins.Comment
