BMW Engine Code Number Reference and Specifications
  • DCColegrove
    • 2748
    From BMW:
    M10
    Straight 4 cylinder SOHC 8V. 1966-1987. 83kg 180lbs
    Used in 1502, 1600-2, E21 316/318i/320-4, E30 316, 2002tii and 2002 turbo
    1.5 (75bhp), 1.6 (85bhp), 1.8 (90-98bhp), 2.0 (100bhp), 2.0i (125bhp), 2.0tii (130bhp), 2.0turbo (170bhp)
    M20
    Straight 6 cylinder SOHC 12V. Baby Six. 1977-1992. 117kg 258lbs
    Used in E21 320, E21 320i/6, E28, E30, E34, E21/30 323i, E30 325e and E28 528e
    2.0i (129bhp), 2.3i (143bhp), 2.5i (170bhp), 2.7e (125bhp)
    M30
    Straight 6 cylinder SOHC 12V. Big Six. 1973-1993. 143kg 315lbs
    Used in E12 525/528, E28 525i, E23 725i, 2800CS, E28 528i, E23 728i, 3.0CS/i/L, 3.0Si, E12 530i, E23 730i, 3.3Li, 633, 732i, 733i, 535i, 635i, 735i, E12 M535
    2.5i (150bhp), 2.8i (184bhp), 3.0 (185-208bhp), 3.3 (200-206bhp), 3.5 (218bhp)
    M102
    Straight 6 cylinder SOHC 12V Turbo. Big Six Turbo. 1984-1986. 145kg 320lbs.
    Used only in the E23 745i
    3.2L or 3.4L Turbo (252bhp)
    M40
    Straight 4 cylinder SOHC 8V. Replaced the M10. 1987-1993. 81kg 178lbs
    Used in post 87 E30 316i/318i, E34 518i, Pre 93 E36 316i
    1.6 (102bhp), 1.8 (122bhp)
    M42
    Straight 4 cylinder DOHC 16V. 1989-1996. 100kg 220lbs
    Used in E30 and E36 318is, Z3
    1.8 (138-142bhp)
    M43
    Straight 4 SOHC 8V. 1993-1998. 83kg 183lbs
    Used in post-93 E36 316i/318i, E34/39 518i.
    1.6 (102bhp), 1.8 (115bhp)
    M43TU
    Straight 4 SOHC 8V. 1998 on. 83kg 183lbs
    Used in E46 318i
    1.9 (118bhp)
    M44
    Straight 4 DOHC 16V. 1996 on. 102kg 225lbs
    Used in E36 318iS, Z3
    1.9 (142-150bhp)
    M50/M50TU
    Straight 6 DOHC 24V/Straight 6 DOHC 24V with Single VANOS. 1989-1998. 136kg 299lbs
    Used in E36 320i/325i, E34/39 520i/525i, Variation of this was used in the Early US E36 M3
    2.0 (150bhp), 2.5 (192bhp), 3.0 (240bhp) Sometimes referred to as S50US. Engine shares more common parts with M50 than Euro S50, but is a motorsport engine.
    M52/M52TU
    Straight 6 DOHC 24V with Single VANOS/Straight 6 DOHC 24V with Double VANOS. 1996-1999. Iron Block in US, Alloy Block in Europe . 118kg 260lbs (alloy) 140kg 308lbs
    Used in E39 520i/523i/528i, E36 323i/328i, E38 728i, Variation of this was used in late US E36 M3.
    2.0 (150bhp), 2.5 (170bhp), 2.8 (193bhp), 3.2 (240bhp) Sometimes referred to as S52US. Engine shares more common parts with M52 than Euro S52, but is a motorsport engine.
    M54
    Straight 6 DOHC 24V with Dual VANOS. 2000-present. 126kg 277lbs
    Used in late model Z3, all E39 and E46 six cylinder models
    2.0 (150bhp), 2.2 (170bhp), 2.5 (184-192bhp), 2.8 (193bhp), 3.0 (231bhp)
    M56
    Straight 6 DOHC 24V Dual VANOS with ULEV. 2002-present. 127kg 280lbs
    Used in some E39 and E46 six cylinder models
    2.5 (184bhp)
    M60
    V8 DOHC 32V. 1992-1996. 146kg 321lbs
    Engine blocks were made of Nikasil (Silicone Injected Nickel) which were prone to failure over time. Many have been replaced with the newer Alusil (Silicone injected Aluminum) engines/
    Used in E34 530i, E32 730i, 740i, 840i
    3.0 (218bhp), 4.0 (286bhp)
    M62/M62TU
    V8 DOHC 32V/V8 DOHC 32V Single VANOS. 1996-present. Alusil Engine block. Pre 98 engines were non-VANOS. 140kg 308lbs
    Used in E38 730i/740i, E39 540i, X5 and 840i
    3.5 (235bhp), 4.4L (286bhp), 4.6 (340bhp)
    M70
    V12 SOHC 24V. 1988-1994. 155kg 341lbs
    Used in E32 750il, 850i
    5.0 (300bhp)
    M73
    V12 SOHC 24V Single VANOS. 1995-2001. Pre 98 engines were non-VANOS. 150kg 330lbs
    5.4L (326bhp)
    S14
    Straight 4 DOHC 16V Solid Lifter Valvetrain and Individual Throttle Bodies. 1987-1991. 106kg 234lbs
    Used in the E30 M3 and Italian only E30 320is
    2.0L (195bhp) 2.3L (192-200bhp), 2.5L (215-238bhp)
    Original S38 (Also known as M88 and M88/3)
    Straight 6 DOHC 24V Solid Lifter Valvetrain and Individual Throttle Bodies. 1979-1980, 1986-1990. 146kg 321lbs
    Used in M1, E28 M5, M6, SA E23 745i
    3.5L (277-286bhp)
    Updated S38
    Straight 6 DOHC 24V Solid Lifter Valvetrain and Individual Throttle Bodies. 1988-1996. 151kg 332lbs
    Used in E34 M5
    3.6 (315bhp), 3.8 (340bhp)
    S50
    Straight 6 DOHC 24V Solid Lifter Valvetrain with Single VANOS and Individual Throttle Bodies. (Dual Vanos on 3.2Ls) 1992-2000. 152kg 333lbs
    Used in non-US E36 M3
    3.0 (286bhp), 3.2L (321bhp)
    S54
    Straight 6 DOHC 24V Solid Lifter Valvetrain with Dual VANOS and Individual Throttle Bodies. 2001-present. 148kg 326lbs
    Used in the E46 M3 and the last of the Z3 M-Coupe and M-Roadster.
    3.2 (321-343bhp)
    S62
    V8 DOHC 32V Solid Lifter Valvetrain with Dual VANOS and Individual Throttle Bodies. 1999-present. 158kg 348lbs
    Used in E39 M5 and Z8
    4.9L (400bhp)
    S70
    V12 SOHC 24V. 1995-1997. 165kg 363lbs
    Used in 850CSi
    5.6L (380bhp)
    S70/2
    Used in McLaren F1 (Was originally developed for M8)
    Type 6.1 liter, 48 valve V-12 with aluminum block and heads, 627 bhp
    Bore and stroke 3.38 x 3.41 in (86 x 87 mm)
    Weight 266Kg
    Displacement 370 cubic in, 6064 cc
    Compression ratio 10.5:1
    Engine control system Bosch Motronic with port fuel injection
    Emissions controls 3-way catalytic converter feedback fuel-air-ratio control auxiliary air pump
    Valve gear Chain-driven double overhead cams, 4 valves per cylinder, hydraulic lifters, variable intake timing Solid Lifter Valvetrain with Single VANOS and Individual Throttle Bodies
    Power (SAE net) 618 bhp @ 7400 rpm
    Torque (SAE net) 479 ft-lb @ 4000 rpm
    Redline 7500 rpm
    M21
    straight 6 SOHC 12V Diesel. 1983-1991 126kg 278lbs
    Used in 324td, 524d/td
    2.4 (112bhp), 2.4 Turbo (115bhp)
    M41
    Straight 4 SOHC 8V Diesel. 1995-on. 108kg 238lbs
    Used in E36 318tdS
    1.7 Turbo (90bhp)
    M51
    Straight 6 SOHC 12V Diesel. 1995-on. 132kg 291lbs
    Used in E36 325td/S, E34 and E39
    2.5 Turbo (115bhp), 2.5 Intercooled Turbo (143bhp)
    M47
    Straight 4 DOHC 16V Diesel. 1998-on. 117kg 258lbs
    Used in E46 320d
    2.0 Turbo (136bhp)
    M55
    Straight 6 DOHC 24V Diesel. 2000-on. 132kg 291lbs
    Used in E46 and E39s.
    2.5 Turbo (170bhp), 3.0 Turbo (183bhp)
    M67
    V8 DOHC 32V Diesel. 1999-on. 192kg 423lbs
    Used in E38 740d
    4.0 Turbo (245bhp)
    N44TU
    Straight 4 DOHC 16V Dual VANOS with Valvetronic
    Used in E46 318i
    1.6 (115bhp), 1.8 (143bhp)
    N62
    V8 DOHC 32V Dual VANOS with Valvetronic
    Used in E65 745i
    4.4 (325bhp)
    N73
    V12 DOHC 48V Dual VANOS with Valvetronic
    Used in E65 760i
    6.0 (438bhp)
    W10
    Straight 4 SOHC 16V
    Used in Mini One, Mini Cooper
    1.6 (90-115bhp)
    W11
    Straight 4 SOHC 16V with Eaton Supercharger
    Used in Mini Cooper S
    1.6 Supercharged (163bhp)
    *Not all US HP Specs are quoted lower HP number denotes US rating
  • LowR3V'in
    • 4209
    Very nice!
    Thank you.
    • Jean
      • 18228
      Is this correct?
      M40
      M43
      M43TU
      Used in E46 318i
      1.9 (118bhp)
      • Danny
        • 14216
        Yeah.
        M40 was the precursor to the M42.
        • TDE30
          • 7042
          Thanks for the info.
          - Trey
          E90 325i/6 (ZSP, ZPP, ZCW)
          E36 325i sedan
          E30 325i sedan
          Volvo 945T
          • hahmeta
            • May 2008
            • 213
            does anyone know what's the meaning of M, S, W, N letters are in engine code numbers?
            or at least what do they signify?
            i guess i could go through the list and try to discern a pattern but i'm too lazy...
            • Jean
              • 18228
              Originally posted by Danny
              Yeah.
              That's not what I was asking though.... seems a little odd that M42 and M44 were DOHC, but the M40, M43 and M43TU were not.
              • Danny
                • 14216
                Oh, well the M40 was indeed 8v.
                Maybe it was based on the M10?
                I don't really know.
                • Kingb
                  • 928
                  The M40 was the worst motor that BMW came out with. They also have a common problem of the oil galley or spray tubes in the head get clogged easy and the cam is made out of a softer metal so the cam lobes wear out and then the engine won't rev over 4K and the engine goes into a limp mode until back at idle. AMHIK
                  Originally posted by Nicademus
                  My car beats off to that car. :bow:
                  • rwh11385
                    lance_entities
                    • 18403
                    Wow. So you don't just take credit for someone else's work when you work with Mason...
                    http://www.bimmerforums.com/engine_faq/
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      scorcher.
                      • DCColegrove
                        • 2748
                        Hmmm...
                        I asked someone I know (a trusted source) if they could send me these specs and this is from the E-mail...
                        Would be interesting to me to know what came first.
                        • kronus
                          • Apr 2008
                          • 13028
                          That would be a serious issue if he had taken credit for that info anywhere.
                          cars beep boop
                          • DCColegrove
                            • 2748
                            Come to think of it...
                            Accusing someone of plagiarism is a pretty serious thing.
                            I'll put up with all kinds of shit but you are very close to crossing that line into the catagory of "Shit I just don't have a sense of humor about".
                            • e34john
                              • Apr 2006
                              • 3599
                              M, is standard production engines
                              S, is Motorsport engines
                              W, I guess is BMW engines that aren't in BMWs but I remember the engines in Minis is a joint project with some other companys and the early motors were sourced from someone else. And I don't know the engine code for Rolls Royce so we can just say W motors don't come in a BMW
                              N, is their next generation engines. First number signifys the number of cylinders, its not a direct though, its still in code and second number is just a variant.
