Alternator modifications:
I like and chose the Delco cs144, there is lots around, parts are cheap and you dont have to solder anything(original stuff). You can use almost any alternator. The theory is the same, but I am only dealing with this alt.
Ive always used the 140amp version, the more power the better
Anyway, there is a rectifier inside that changes the current from high frequency three phace AC to high frequency DC. But the original rectifier lets the smoke out the second you try to weld through it. This is becuase it has avalanche diodes and I believe they are set up to blow if the volts get to high. Simply as a safety measure for your cars electronics.
You have to take the alt apart and replace the rectifier with a Transpo Part# dr51173 Rectifier. It works like a charm
Also take out the regulator, and throw it in the garbage.
Next, Solder a wire to the terminal where the regulator was attached to the field coil brush. And run that wire outside of the case.
I drill a small hole, slip the wire through and JB weld it in so it doesnt move around. and put it all back together. You can clock the case around as well to move the post to the best spot.
and mount it on your engine/electric motor
now you have a power supply.
put 12V in the wire you just installed and you have welding current.
the easiest way to use this is to install it into a vehicle.
Go and buy a ford external regulator about $10
I can't remember the the letter designations right now but you run one wire to it that is turned on from the ignition key to power it.
On wire straight from the battery, so it can sense the battery voltage, and one to your new wire. that one runs it. On the regulator there is an extra terminal, you dont need it but you can use it to run the charge light in your dash.
once thats all hooked up you just hook the Batt. terminal to the battery. and now you have a very nice 140 amp 12v charging system for your vehicle.
Now all you have to do to weld is take the batt. wire off of the battery, and hook up your stinger....
!!!straight from the batt. terminal on the alt to the stinger, nowhere else!!!
and a negative clamp to the vehicle chassis.
Run the engine.
I hooked up a hand throttle by using a bicycle gear shifter to the throttle, in order to idle up and set the RPM. the faster the engine the more power you get. and that's how you set the heat. if you rev it up to about 3500 you can run angle grinders and brush motors.
What happens is the regulator thinks that the alt isn't charging (becuase the output isnt hooked up to the car 12v+), and it puts out max power to the field coil. I swear it is the best arc welder I've ever used, the HFDC is super smooth and burns nice and deep.
We now have a power supply.. modified alt, and a electric motor.
We need to power the field coil with adjustable voltage.. so we can adjust the welder as we need it.
Becuase all we have in the new welder is 208VAC to run the electric motor..
(You may have 240VAC or something else... whatever
We need to find a way to make it 0-12VDC
So I got a step down transformer fromt the local electric supply.. you can see it in that pic, its the big blue box.
It has two seperate input coils, and two seperate output coils
they are wired in series. 208 VAC in one side and 25VAC out the other
Getting closer I know have 25VAC....
