Okay, here goes nothing. Unfortunately I don't have pictures or measurements for everything, but if any of you decide to go for it, it's pretty straightforward.
Things you need
-Check panel
-e34 dome light
-soldering iron
-wire
-plastic bonder
-dremel with cutoff wheel
-some form of sandpaper/sanding drums/files etc.
-patience :)
though the whole thing, remember that it is always easier to take material off than it is to add it back. I kept the entire assembly a few millimeters too long with every cut I made just to be safe.
First, take a check panel and cut the back off. It doesn't have to be pretty, because you won't be using the back again; just the sides. You can try the 318 blank panel, which deoesn't have to be cut, but I think the lip on the short edges is too short to hold the light in place.
Anyway, here's a pic of the panel with the back off:
The innards of the panel pull out. There are small nubs on the inside of the housing that hold everything in; with a hard enough push, everything pops right out. It may help to pull outwards on the long sides of the panel just to create a little more clearance.
Here's a pic of the innards removed:
All of the parts are stacked on top of each other:
Next, take the e34 light and pop the plastic lens off of the opaque housing. It just snaps on. Be careful not to break the tabs, because you will need those to reassemble everything. Unfortunately, I don't have pics of this.
The lense needs to be cut down to length first. You will use this as a template of sorts to figure out where to cut the frame later.
This is where the entire project becake a bit of a trial and error project. The length that I cut out was roughly 4.5 cm long. I'd start with cutting out 4ish cm and going from there to make sure it all fits. It should be pressed snugly between the two ends of the check panel housing. Do not cut between the two switch holes, because that will make it downright impossible to modify the frame. I suggest using a dremel and cutting along one of the black sections of plastic like this:
The center part can be discarded, so you end up with this:
When you get the correct length, it will essentially hold itself into the housing with friction. The nubs on the inside of the housing keep it from falling out of the bottom. Final product of this step will look like this:
In my car it didn't matter which way the housing snapped into the check panel hole. I'd assume this works for all e30s, but the 318 may be different with its incomplete panel. If it does matter, just be sure to pay attention to the orientation of the map lights when you are modifying the lense, as they are directional.
The next post will show the harder part-getting the frame to work. It might take alittle while for me to post this because I have to go run some errands. Real life calls...
Things you need
-Check panel
-e34 dome light
-soldering iron
-wire
-plastic bonder
-patience :)
