What’s up R3V, This is a very easy DIY project for a kick panel light for driving at night. I wanted to light up the interior some while driving at night so I came up with this solution. I wired up the light to my headlight switch (red/grey power). You can also wire this up to your door jamb switch for the interior lights. Hope this helps! Thanks for taking a look.
TOOLS/PARTS NEEDED:
I had some extra light assemblies laying around. Decided to go with a glove box light. You could also use a trunk light
fitted up the light where I wanted it. I put mine pretty much in the middle of the 3 pedal cut outs
Marked out the outline with a pencil
I used a utility knife because that’s all I had at the moment. If I were to do this project again, I would most likely use a Dremmel with a cutoff wheel
TOOLS/PARTS NEEDED:
- wire cutters
- 8mm socket
- 1/4” drive ratchet
- phillips screw driver
- wire connectors for the switch and quick connects
- Shrink tubing
- light assembly
- 6418 bulb
- shears
