M50 Camshaft Sensor with Megasquirt MS3X (Pullup resistor? Internal jumpers?)
  • Ashton1234
    • Aug 2023
    • 4
    Hey guys.
    Swapped a m52b28 from a 528i into my 318i E36 and went with a MS3X for my ECU as the stock ecu had some issues.
    I've got every sensor working and everything else wired up but I'm having issues with cam sensor.
    I swapped the m52 cam sensor out with an m50 cam sensor as per recommendation. The sensor has 3 wires: Red, Yellow, Black. I'm running 12v fused to Red, Yellow to Cam input and Black to Sensor Ground.
    I'm not getting any cam signal during cranking so I tried adjusting the R32 and R11 pot as per manual (Remove Js7, adjust, apparently put back Js7 according to Pazi88)
    I'm seeing forums about requiring a pull up resistor but I'm not sure if this is necessary and where to install it. The sensor is an OEM replacement: bremi 60156
    Thanks!
  • Panici
    • Dec 2009
    • 2576
    From my build thread. Hope this helps.
    M52B28 with MS3X
    It took some testing to find that I needed an M50 camshaft sensor using a 1K pullup resistor to +5v.
    Also needed the DIYAutotune Hall Effect crankshaft sensor with pullup resistor to +12v. Key point here was that this needed to be mounted to the front (OBD1) crank sensor location. I could not get it to read correctly with the rear sensor location in the block.​
    • ADEN
      • 620
      M52B28 with MS3X
      Are you sure that crank signal input needs a pull up reaistor to +12?🤔
      Hall crank sonsors trigger input in stock ecu and most of standalones is PWM 5V.
      • Ashton1234
        • Aug 2023
        • 4
        M52B28 with MS3X
        Sent you a private message to follow up on some questions, thanks!
