anyone using a war chip that could send me a base tune?
  • dmjensen
    • Jan 2011
    • 805
    i have a war chip on it's way and I'm finishing up getting my turbo set up together waffleswaffleswaffles's anyone wana help me out and get a decent enough tune to get me started? :up:
  • MonkeyMadness
    • 3251
    Good Luck..!
    • dmjensen
      • Jan 2011
      • 805
      Haha at this rate i'll be tuning it myself
      • The Humjet
        • Jun 2010
        • 528
        Tuning from scratch with a W.A.R will take forever. Your better off getting hold of Brody and work off his base tune. The W.A.R chip wasn't designed to tune from scratch if you wanna do that then your better off going with Megasquirt
        • dmjensen
          • Jan 2011
          • 805
          lol i already have the war chip ordered, so how do i find said brodyz?
          • The Humjet
            • Jun 2010
            • 528
            You can go through members list at the top of the screen and find "brody" and click email. He says that's the best way of getting in contact with him or pm him which should go to his email anyway. Then simply ask for a m20 turbo base tune. I think you have to pay for it though unless you ordered the m20 turbo package.
            • dmjensen
              • Jan 2011
              • 805
              I did not, i just ordered the chip. I didnt have the funds for the maf conversion
              • euro2fast4u
                • 545
                so your just running a war chip with the stock afm?
                • dmjensen
                  • Jan 2011
                  • 805
                  Yes, thats my plan
                  • euro2fast4u
                    • 545
                    the afm is unable to measure the incoming air when its above atmospheric pressure. meaning any positive boost pressure will keep the afm open. Thus you will be running very lean and causing engine failure. there's more then just bolting a turbo up and adding a chip. you need fuel control and addition fuel and a way to measure the incoming air. either a maf or a map sensor.
                    • dmjensen
                      • Jan 2011
                      • 805
                      Several people have tols me the afm will be just fine and the war chip is programable so i can tune everything. but like humjet said tuning from scratch would be impossible. in not just slapping on a turbo, i reasearched what i need to do
                      • The Humjet
                        • Jun 2010
                        • 528
                        Might I like to add that the miller m20 turbo base tune is designed to run their 3.5" draw through Maf sensor. Better talk to Brody however to confirm about tuning a turbo with an AFM.
                        • MonkeyMadness
                          • 3251
                          ^ yes that's true...
                          But There first turbo build and a few after were AFM, so it possible to do.
                          Problem is if you ain't got the coin for the maf convetion, you ain't got the coin to buy a tune form brody $$$..
                          Best bet is to find some one with the tune you can borrow..
                          This is why I went MS and ditched the MAF, and AFM..
                          Humjet's now running my old (war/MAF) setup and I can't wait to see his project finished!
                          • BMWZ318is
                            • Nov 2008
                            • 102
                            i have an m20 that is turbocharged and im using the war chip and the stock afm i have a few tunes i worked on my self i can send to you in still working on the idle adjustment for when the motor is cold but i drive it everyday with 8lbs and it runs pretty good. Eventually i will be getting the upgraded maf. heres my email if you need the tune drivefastthinkslow@live.com -zac
                            • MonkeyMadness
                              • 3251
                              Wow.
                              That's very nice of you..
                              Soo un-R3v like... props to you my good man!
