Well, the WAR chip seems to be giving me lots of trouble. I thought with the 5 speed, tuning would be simpler because it wouldn't downshift on me but I'm still having issues. I hope Brody can offer some help.
My cruising AFR is fine at light load I'm between 14.7 and 16.1 constantly jumping back and forth.
at higher load like going up the highway I'm at a consistent 13.5 AFR.Which to me is also ok.
WOT in first gear at 4.5krpms I shoot down to 9.8 AFR and the car bogs.
My logic behind the first gear bog with the WAR chip; that other users also have, is because boost hits later in first gear but the ECU still sends in fuel for air that is not there.
If I tune this away with less fuel than I am LEAN in every other WOT pull in other gears.
in second my AFR is around 11.8 and third around 12.4-12.8. At 11.8 it pulls strong and hard.
I've taken away LOTS of fuel from the base map and really cant take away anymore because then I'm lean in other gears.
I have not touched my ignition maps simply because I don't know how to do it effectively. SO I'm here for help.
BELOW is the MILLER FUEL BASE MAP. With this the car is almost un drivable my cruising AFR is in the 9's and I can hardly go WOT.
Below is MY fuel map which works good for everything but first gear and occasionally it will load up on fuel during spirited driving and want to stall out unless I blip the throttle coming to a stop. I have raised my idle to around 950rpm once warm but it doesn't seem to help the problem.
and below is my untouched ignition map(same as Miller ignition map). Somehow the RPM got cut off but its the same rpm range as the fuel map if i'm not mistaken.
Any input is appreciated. I'm at 9.5psi
