the car will randomly not power up the ecu after driving and then randomly start working (not for long) after sitting. i can't seem to develop a pattern to chase the issue down. NOTE i have had 7 different main power relays the first 2 were known good used the rest were new all factory bmw and 1 bosch.
using this diagram to check the pin outs on the harness at the ecu (with it disconnected and key on and off as follows:
link to diagram http://www.megasquirt.325ix.com/MS_t..._motronic.html
with the ecu disconnected and the key on it reads as follows:
#2 no ground
#3 ground, but no buzz (indicating a weak ground)
#14 has no pin
#19 ground with key on
#24 ground with key on
#36 reads (+) should be ground and reads the same key on or off
#37 reads (-) with no buzz key on or off
at the main relay:
key on:
#30 (-)
#85 (-)
#86 (-)
#87 inside nothing
#87 outside nothing
key off:
#30 (+)
#85 (+)
#86 (+)
#87 inside (-)
#87 outside (-)
sometimes the main relay will rapidly click, but again without any pattern, just sometimes.
ALSO: i have run the MS seperate from the car on the stim with the laptop and let it run for 4 hours cycling it off and on with the toggle switch 50+ times and everything seems to be working correctly with it on the stim.
#2 no ground
#14 has no pin
at the main relay:
key on:
#30 (-)
#85 (-)
#86 (-)
#87 inside nothing
#87 outside nothing
key off:
#30 (+)
#85 (+)
#86 (+)
#87 inside (-)
#87 outside (-)
