What Chip + What
  • aPapester
    • 215
    What Chip + What
    Im wanting to get a chip but no idea where to start, completely stock engine want it to have better throttle response and all that. also should I get bigger injectors
    excuse my "noob"
    Check Out My Photography
    aPapester Photography Facebook
  • aPapester
    • 215
    bumpski
    • LowR3V'in
      • 4209
      http://www.turnermotorsport.com/
      or
      enjoy your 5hp and negative $250. ;)
      • george graves
        • 20003
        Hehehe. Sounds about right. In all fairness - it might be more like 7 HP.
        There's about a dozen different mod I'd do before a chip that will totally transform your car for $250. Such as:
        - a suspension rebuild
        - e36.z3 rack
        - diff swap
        - Delete trunk tar (free)
        - 2 cans of seafoam and clean your injectors...(that's 2-3 HP right there at least - about $15)
        - New plugs, air/fuel filter.
        Originally posted by Matt-B
        • Garageaholic
          Freestyle Fabricator
          • Dec 2005
          • 5204
          I was always afraid of deleting my trunk tar, George. Weight distribution and all. Id hate to have my rear end kick out when I'm taking a corner
          Recent Rebranding!!
          E30 SM62/S62
          E30 M60 V8
          E30 M30 Big 6!
          Instagram.com/garageaholic
          Youtube.com/garageaholic
          • george graves
            • 20003
            On a 2700 pound car, 30 pounds is nothing for weight distribution front to rear. (but I guess you were just kidding!)
            • aPapester
              • 215
              i wasnt looking for the + hp but more of the pulls stronger all around, higher redline thing.
              " Horsepower Gain+ 24 @ 4500 RPM
              Torque Gain+ 28 @ 4500 RPM
              New Rev Limit 5300 RPM "
              so thats just a load of shit?
              • Mr. Tasty
                • Jul 2011
                • 3421
                that's for an eta
                eta chips make a bigger difference than b25's
                2014 Alpine White 335i MSport
                (Daily Driver)
                Full Mperformance Aero
                KW V2 Coilovers
                VRSF Catless Downpipes
                • Mr. Tasty
                  • Jul 2011
                  • 3421
                  hey george, I already put in 5 oz for 5 gallons of fuel of seafoam. Where else should I put it?
                  (Daily Driver)
                  KW V2 Coilovers
                  • aPapester
                    • 215
                    i have myself an eta
                    • Mr. Tasty
                      • Jul 2011
                      • 3421
                      a chip for an eta will be the biggest and more felt change.
                      (Daily Driver)
                      KW V2 Coilovers
                      • aPapester
                        • 215
                        so your saying its worth the 200 bones?
                        • george graves
                          • 20003
                          Don't bother putting it in the tank. It's not strong enough to do much more then clean your injectors (and you should be running gas with a injector cleaner like Chevron anyways)
                          You want to slowly suck it into the manifold via a vacuum line. There is a line on your intake manifold you should be able to pop off, start up the car (let it warm up to above the blue line. It should be warm, but not hot - too hot and you'll burn off the sea foam. Tooo cold, and the sea foam won't work as well). Slowly let it suck an air/seafoam mixture into the manifold - it should be making a slurping sound. You can also bob the tube into the can - that works ok too. If you start to hear knocking, you're add it too fast - slow down - that's bad for your motor. If the engine isn't struggling to keep idle you're adding it too slowly. Suck 1/3 of the can in and then and shut the motor off(don't rev the motor at all). At this point there should be very little smoke. Let it sit for an hour, and do it again. You should be getting some smoke going this time. Again, shut it down, and let it sit. Do it one final time, and then let it sit for 10 mins. Now, go drive the living piss out of your car - red line the car in 1-2-3 gear - speed up, hard on the brakes, and then pull hard - over and over (you're trying to blow the carbon deposits off of the valves and piston tops) . You'll be generating a smoke cloud about the size of a house in one continuous stream trailing behind you. I kid you not - if your e30 could fly, you could go sky writing with the amount of smoke it will make.
                          Warning - this will get the attention of the police - and by standards will think your car is on fire. It's comical the amount of smoke this will generate. Keep driving hard until all the smoke is gone. (I usually end up on the freeway for a final o-80 pull or two) You'll instantly feel a sharper throttle response - and pick up a few HP.
                          Hope that helps.
                          • e30trooper
                            • 11576
                            i have a eta DME with a ebay chip , ill ship it to you for $75, chip is already installed. Basicly pnp for you. LMK
                            • Mr. Tasty
                              • Jul 2011
                              • 3421
                              Hope that helps.
                              which vacuum line? or can it be any? I have a b27
                              (Daily Driver)
                              KW V2 Coilovers
