who can tune around here?
  • knuklehead92
    • Aug 2011
    • 732
    I am located in nova, burke va,
    I am thinking about doing a m20 turbo, is there any body in the area can tune m20 turbos around here? If so what engine management do you guys use or perfer?
    Trust me it stock :yawn:
  • sayed ali
    • 762
    V.E.M.S
    ms pnp
    W.A.R chip
    M20B28 Turbo
    My Build Thread
    http://www.r3vlimited.com/board/showthread.php?t=255839
    • CarsSuck
      • Oct 2005
      • 968
      Yoshi, SN shiboujiwhatever got his car (MS) tuned at Moore Automotive. I think he had all good things to say.
      --Will
      • knuklehead92
        • Aug 2011
        • 732
        he did but i believe moore was unable to finish and the car was tossed to technica, can anyone with a m20 turbo vouch for moore?
        • CarsSuck
          • Oct 2005
          • 968
          try PMing FrozenSolid then. His car is a beast.
          --Will
          • Jaxx_
            • Dec 2009
            • 1880
            since so many people run MS, I would suggest that and run a less aggressive version of someone's already tuned tune.
            • FrozenSolid
              • 276
              i live in fairfax (not far from you), and run megasquirt in my turbo e30. I did alot of street tuning on it to get it as close to perfect as i could, and then took it to moore automotive to do my timing map and touch up fueling. I think the trick with megasquirt is getting comfortable at datalogging/adjusting tables yourself. Otherwise, the tuner is going to spend alot of time/cost you alot of money to get the car spot on. Megasquirt is pretty basic as far as engine management is concerned, and you should be able to learn quick.
              I beleive yoshi's issue with moore automotive was more of a timing thing (they couldnt get to his car in time) but i may be wrong. They seem like a very capable shop and chris, the tuner, is knowledgable and good with megasquirt.
